sorry if this is in the wrong bit or if im not alowd to do it but i thought that its a good oppertunity for every 1 to save some $$$$$ at some1 elces expence!*** american $ ***
another "crapy" forum is having a 25% o
ff tein coilovers and springs
http://www.tein.com/nissan.html <---- go here get a price
take20-25% off
then here to order them! |
V
http://www.automotiveforums.com/vbulletin/t173913.html
mark
https://www.sau.com.au/forums/topic/32025-cheep-coilovers/
yea i sent them an e-mail bout that, Listed below is the coilover kits that we
offer for the Nissan Skyline R32. If you have anymore questions please feel
free to contact us. Thank you for your interest in Tein High Performance
Suspension,.
HA
TEIN has developed advanced technology to design the shell case and stroke
to bring out the full potential of your vehicle. These features of the TEIN
HA Damper kit were designed with greater performance to satisfy
all your driving demands. This high performance damper can be used for
weekend racing and/or daily driving. The discomfort caused by uneven roads
or bumps are eliminated on daily street use. For race use, the ride height
adjustable system enables you to adjust ride height and 16 levels of damping
force. In other words, you can adjust your vehicle to meet all situations!
- High performance and cost effective
- 16 levels of damping force adjustment (compression and rebound together).
- Ride height adjustable
- New paint coating for rust prevention.
- Pillow ball mounts are optional (on certain applications).
- Available for overhaul in North America.
- MSRP $1400.00
FLEX
TEIN has used its years of experience in various motor sports to produce a
kit that provides the ultimate balance between comfort and performance. The
FLEX Damper Kit features the latest technology for all drivers who are
seeking comfort, performance, and adjustability. We have incorporated
separate spring perch height and shell case length adjustment, which allows
the suspension to retain more stroke and allows for more suspension tuning.
The FLEX Damper kit includes pillow ball upper mounts, which increase
steering response, and is compatible with the EDFC (Electronic Damping Force
Controller), for added convenience and adjustability.
- Full-length adjustment and height adjustment for separate setting of the
height and spring preload.
- Teflon coating for rust prevention.
- Newly designed spring seat and spring seat lock for easy height
adjusting.
- Pillow ball upper mounts are included.
- Compatible with EDFC.
- MSRP $1480.00
CS
TEIN Type CS damper was designed to give comfort to sophisticated drivers.
We adapted a hard rubber upper mount for noise proofing and increased
steering response. A mono-tube type shell case was utilized to increase
valve size and oil capacity for improved comfort and handling. CS was made
for those who want aggressive looks, and increased handling with out
sacrificing any loss in comfort or added noise.
- Improved ride comfort over original shock absorbers.
- Hard rubber upper mount is used for noise proofing.
- Ride Height Adjustable
- A mono-tube design and increased shell case diameter to allow for 30%
more oil capacity, as compared to OEM shock absorbers to handle the upsizing
of wheels with lower profile tires.
- Available for overhaul.
- MSRP $1660.00
RA
TEIN RA has been designed for circuit racing and aggressive street use for
experienced drivers. It incorporates mono-tube design for larger valves and
increased oil capacity. Maximum road handling and driving stability is
achieved through aggressive spring rates and damping force.
- Mon-tube design for maximum performance.
- Constructed of A7050 aluminum for weight savings (on certain
applications), strut type suspensions have an inverted steel shock absorber
for durability.
- levels of damping force adjustment (compression and rebound together).
- Ride height adjustable.
- Exclusive designed pillow ball upper mount for optimum performance.
- MSRP $1770.00
RE
The Tein Type RE is like the Type RA, but with an added full-length
adjustment system. The ride height is adjustable without changing the
preload of the spring. This is the special feature of the full-length
adjustment system due to threads on the lower bracket. The Type RE has a
wide range for setting the stroke and length of the shock. It is possible
to set up this suspension for various road, weather, or track conditions
while maintaining optimal suspension stroke. Features include: mono-tube
design for larger valving and increased oil capacity, aluminum casing for
weight reduction, Full-length adjustment and height adjustment for separate
setting of the height and spring preload, 16 levels of damping force
adjustment, pillowball upper mount, and available for service.
for durability.
- MSRP $1900.00
RS
TEIN has used its years of motor sports experience to develop a kit for
ultimate damper tuning. Type RS damper gives the user separate compression
and rebound adjustment (16 levels x 16 levels), which allows the driver to
set up the suspension damping force to meet any track conditions.
Furthermore, wishbone suspension and multilink suspensions have a reserve
oil tank for larger oil capacity, to reduce added heat from track racing and
performance driving. Strut type dampers are designed with inverted shocks
for more horizontal stability.
- Mono-tube design for maximum performance.
- Compression and rebound damping force is adjustable separately (16 levels
x 16 levels).
- Extra reserve oil tank for larger oil capacity for wishbone and multilink
suspension.
- Inverted structure for more horizontal stability for strut type
suspension.
- Exclusively designed pillow ball upper mounts to optimize performance
- MSRP $2310.00
Best regards,
Sales
Staff @ TEIN USA INC.
9798 Firestone Blvd.
Downey, CA 90241
Phone: (562)861-9161
Fax: (562)861-9171
www.tein.com
https://www.sau.com.au/forums/topic/32025-cheep-coilovers/#findComment-643515
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
