  • Replies 137
Goodmorning Everyone!!
If you did not provide me with your full name and phone number, then PLEASE send it to me ASAP as you will be asked for proof of identity when you take your car in, If you dont and someone uses your username and gets your tint, then I cant be responsible and neither can Auto Perfection!
You will be asked to confirm your tint details when you call up, so dont stress if you have changed your mind between 20 or 35%.
:yes: Here is the PAID list!!! :thanks: 23 Cars!
Ontheranch: 35% - PAID
Skylineguy19: 20% Silvia: PAID
Skylineguy19: 35% Falcon- PAID
Krishy: 35% - PAID
Cronic: 35% and tint removal- PAID
ImportS13: vr4 20% PAID
Typevu: 35%- PAID
Blue32: PAID (from last group buy)
Pistol-Pete:35%-PAID
DOMN8R: 35% -PAID
Damo_R34: 20% two front: PAID
WLD MAN: 20% R33: PAID
Brad20:20% and rear tint removal: PAID
Tommmo:35%- PAID
Jap_Star:35%- PAID
Whale: 35%: PAID
Rush33: 35%: PAID
Ripp3r: 35%: PAID
Pyro-ns: 35% stag front windows: PAID
Pyro-ns: 35% Colt: PAID
SkyHi 33: 35% and 20% rear: PAID
KbaTz: 20%: PAID
Amaaru: 35% PAID
I have not received payments from the below-
2. Hotwire: 2 front, 20%
25. MrRS4: 2 front 35%
22. Calais VL:35%
If you have transfered money and it is not showing in my account, please provide me with receipts ASAP as this transaction will be going through in a few hours!!
  • 1 month later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
