Hi everyone,
Background:
The car is an R32 skyline with 139,000 kms on the clock. It has been well maintained engine looks tidy and has full log book history. The car is pretty much stock, the only mod is a full 3 inch zorst inc metal cat and 3inch dump off the stock turbo. So stock air box and stock intercooler all in wonderful condition.
Problem:
Very randomly the car will do the following;
- While driving, whether under boost or just driving steady, the engine will cut out and cut back in again.
- When stopped engine will run lumpy and stall and starts fine afterwards. (this happens occasionly, not as much as the above)
- Heavy engine vibrations when in higher rev range.
Steps taken to try and fix:
- changed fuel filter
- cleaned air filter
- checked spark plugs (iridiums in excellent condition)
- checked fuel pump filter (in tank)... little bit of crap in there. Cleaned with kero, dried and reinserted into tank.
- did a basic test on coil packs 1,2 and 5 (easiest to test without removal). I wasnt to sure on the resistance levels but the three were consistant with eachother.
- inspected afm... looks tidy. (did this because was a bit worried about k&n panel filter being over oiled from previous owner)
Nothing has changed a single thing into the way it is running. Can someone please help me diagnose the problem, its ripping my brain appart arg!
Cheers, steve
Edited by =STEVE=
https://www.sau.com.au/forums/topic/320315-please-help/
i think we need a little bit more info here..
are your iridiums gapped to .8? or higher?
can you tell the difference between a missfire and a rough idle? if it is a missfire it will most probably be a coil pack. could be a plug too. just because the plug looks good doesnt mean it is good.
will the engine rev over 2300RPM when it is playing up? if not it is most likely your AFM.
could also be a boost or vac leak but it seems unlikely considering you say the problem is intermittent. a vac leak will cause a rough idle and possibly stalling depending how bad it is.
any more accurate info will help us diagnose your problems
https://www.sau.com.au/forums/topic/320315-please-help/#findComment-5228802
well the plugs are gapped right, checked the part number with repco all good there.
sometimes it will idle fine but other times the idle is irratic... say 600 rpm to 1200rpm etc.
The engine revs fine. Just tonight when i was driving it cut out in the middle of the street so when i eventually got it restarted i dropped the shit out of it and it lit up the tyres fine. Then i few seconds after normal driving it cut in and out again.
The intercooler piping is stock and havent touch it so i think its unlikely to be that. Also it would not account for the total randomness of it all.
When i do get in a chance to up it my aftermarket (autometer gauge) reads normal and holds at 12psi.
Also the engine does clunk out when its cold so i dont think that its the coil packs because i have herd they usually only tend to bugger up when hot.
cheers
https://www.sau.com.au/forums/topic/320315-please-help/#findComment-5229496
cheers
the idle could be something to do with your i think its called the IAC motor i think thats what its called, solinoid up the back near your plenum could be dirty or have crap in it that affects the airflow, or the other thing to check would be your stock BOV could have a leak, when i installed an atmo bov on my old r32 i used to get a similar problem exactly like yours cause it didnt like the venting to atmo and rb20's are know for it.
https://www.sau.com.au/forums/topic/320315-please-help/#findComment-5229538
Yea i've heard of the bov causing trouble if vented to atmo. But it looks quite tidy as said its only done 139,000ks. But i will look into that.
IAC sounds like a good candidate because it effects the engine depending on the amount of load? Is that right? But anyways il look into that, cheers!
Keep the suggestions coming guys, can use as many as possible. Its so fkn wierd! I've never seen this sort of thing happen before. lol
https://www.sau.com.au/forums/topic/320315-please-help/#findComment-5229618
Just an update:
I was driving this morning for about 10 minutes and the car ran fine???? WTF ????
So it may have something to do with the tempurature because it was under 10 degrees here this morning.
Keep the idea's coming guys!
cheers, steve
https://www.sau.com.au/forums/topic/320315-please-help/#findComment-5230299
Does it die while driving (actually cruising at say 2000rpm) or when you are coming to a stop?
If it's the latter I would be looking at your AAC/IAC valve, rip it off and give her a clean out with carby cleaner. Quite easy to do.
If it's while you're driving and putting some power into it I would suggest it would be spark related so coilpacks, plugs blah blah blah.
The vibration at high RPM is an interesting one though. Could it be timing related?
https://www.sau.com.au/forums/topic/320315-please-help/#findComment-5230730
i would say now from the extra info that you could have a dry joint in the AFM. mine did some of that drive fine then cut out for no good reason crap and it ended up being the AFM pins inside the unit had dry joins. i just reflowed the solder and now it hasnt missed a beat.
try swappng AFMs with a mate if possible.
https://www.sau.com.au/forums/topic/320315-please-help/#findComment-5231032
Yeah have/had the same problem in my 32.
Would cut out whether in boost or not.
I replaced the AFM instead of cleaning it as they arn't that expensive & fixed the cut in & out.
In regards to your lumpy is it when your coming to stop or say when your sitting at the lights.
I've heard dirty AAC, leaking bov or VAC leak..
https://www.sau.com.au/forums/topic/320315-please-help/#findComment-5232838
My r32 used to have the same problem, lumpy idle and when i would give it to it would splatter only when it was warm. turned out one of the knock sensors was not plugged in theres two one near cyl 5 and other near cyl2 just under the intake manifold make sure there in or put ur ecu into diagnostic and check for error codes
https://www.sau.com.au/forums/topic/320315-please-help/#findComment-5234243
hey everyone,
I fixed it! thank gawd!
It ended up being the afm... The K&N pannel air filter must have been over oiled (previous owner) and it irritated the afm. So i bought some specifically made afm cleaner and pissed the filter and air box off and replaced it with hks ram intake (mushroom type)
It now runs primeo! sounds way cooler too. Heaps of suction!
Thanks for everyone that contributed, really appreciate the help.
cheers,
steve
https://www.sau.com.au/forums/topic/320315-please-help/#findComment-5234719
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
