Does only the left HL turn with the steering wheel?
That's all my car does. There is a picture in a user manual that seems to indicate this light is the only one that moves and goes 30 degrees.
Makes sense too, as you already sit on the RHD of the car.
Does anyone have BOTH lights moving around corners?
https://www.sau.com.au/forums/topic/320716-v36-directional-headlights/
I'm sure I've noticed the driver's side light move, but only when moving at speed
keep an eye out next time you're driving at night
They both move, tested couple of hours ago. There is something strange about right one though. It seems that it does not move until you trun wheel to certain point where left one does it instantly. i though that it was broken at first :devil:
Hmmm... my 'AFS' warning light flashes too.
Methinks they buggered it up during compliance. Once I get the Xenons to put back in I'll get someone to check it out. Hopefully it'll be a matter of putting them in and they'll just work.
BTW the 'Auto' lights are awesome!
Have figured it out.
My workshop told me the right one does not swivel right as to not interfere with oncoming traffic when turning right.
Makes sense and consistent with the Japanese pic in my manual.
My error is most probably just because the Xenon bulbs are missing.
Edited by Haxorz
Anyone put Xenons back in yet? I have bulbs but reluctant to open it up myself.. Anyone knows specialist in Sydney who does this and at what cost?
I haven't... yet...
There is one V36 compliance shop in Syd and in Brissy. I don't know the Syd one but if you find out you can try them.
Otherwise I would have thought any auto elec should be able to do it. My brother (a shop fitter, not a mechanic) did my R34. I was quoted $100 or 150 for this once from memory... seemed a little high for what most guys can do themselves (except for me, being a very unhandy man).
I was told easiest way to do is to put the car up on a hoist and remove the wheel to gain access through behind the front 1/4 fender.
Taking off the front bumper is NOT recommended - it can stuff up the airbag sensors (even with the car off).
I refitted my HID's myself ... took around 2 hours to work it all out..
easiest way is jack it up, take the wheel off, take the inner splash guard off, connect the HID's to the existing ballasts, done!
If your importer was nice he will make it easy to revert it back!
Aussie standard H1's are CRAP honestly there is no comparison i could barely drive at night with the shit that the HID's were replaced with!
oh, and if your thinking of changing the fog lights... good luck! they are an absolute BITCH to get to! most pain in the pass job ever!!!
Thanks for the info.
I was still thinking of taking it somewhere, as I want to fit a band expander and wire in a USB charger for my Tom tom while I'm at it. Maybe even do an iPhone charger (apparently even with the iPod cable the 3GS won't charge) and talk to them about wiring in a little set top box (for TV).
Is it the one for FM Radio?
Yes. Speaking of which, has anybody done this to a V36? Would be good to know what adaptor is required. Apparantly the V35 is a little different. Assuming you can buy these from Jaycar, have also seen some made in NZ ones too.
there is an ipod cable for v36?
( i know americans got one, but jap spec models dont have a cable available i thought?)
My port looks the same as the US one but to be honest I don't know.
My port looks like that, but I don't have the cable. Nor the 'BOSE for Skyline' badge, even thought I have the BOSE stereo (SP model).
Mines all Infiniti badging anyway.
BTW am in touch with a company in NZ that makes the band expanders - only $30 NZ delivered for very high quality ones.
Still need to work this out: 'Also I would need to know what type of antenna plug is in the back of the radio unit eg. A single plug or a twin pin plug as these model vehicles varied."
Anyone know?
  • 8 months later...
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
