As topic states. Have a gearbox that came out of my 32 GTR.
Box felt perfect to drive, no abnormal noises or problems with it.
has GREX stamped on the sandwhich plate. have not pulled the box apart as yet.
Have been trying to find some info online for the GREX boxes. however I can't find any.
Inspections are welcome, will pull the box apart for you if you like.
Gearbox is at my work. in Hamilton QLD.
Can ship the box anywhere in australia, we use fastway or couriers please. If you wish to get a quote from them for it (on a pallet)
Do have forklift, and can use any courier company you wish.
closest info I have found so far is on this website.
http://www.skylinepower.com/gearboxes.html
However, I don't believe it's a 6 speed box. Will check on tuesday.
As for price. Let's start at $4200ono.
Buckna.
0427282562
https://www.sau.com.au/forums/topic/320785-grex-r32-gtr-gearbox/
If its not a 6 speed and there is no different sounds or feeling then its just be a standard gearbox with a grex billet sandwich plate...If thats the case the price is way way way off...
Maybe you should check what you have and then re post??
It is definently not standard.
At least I don't know any stock gtr box that can do the entire archerfield track in first gear with ease.
gearing is alot higher than standard. I'll pull it apart and check.
once again, inspections welcome :)
you really should have confirmed what it is before selling, taking pics will help as well since you are asking big bux for second hand parts on the forums. Especially when inspections is not an option as it looks like you are planning on selling to interstate buyers.
Edited by s2d4
It could even be a 6speed helical type grex box...
But if its not 6 speed then it cant be trust as they only got 6speed done by quaife
im keen to find out what it is...Suprises are always fun lol
Isnt it awesome how people can slap a 4 grand pricetag on something they dont even know anything about. Nice one.
and also not know if its a 5 or 6 speed?? yet can tell us that "it can do the entire archerfield track in first gear with ease"
SMS your mobile,waiting for more info
cheers
Alex 0433 878905
Mordialloc 3195
www.jds-auto-imports.com
Buckna.
0427282562
You guys are cute.
Gearbox came out of an ex competitve drift car in qld.
I never drove it archy myself. Drove
it onto tow truck and into drive way then stripped it down.
As I said, I've been busy with events till today.
Pending how much work comes in today I'll try pull it down today and take highres photos.
Inspections are welcome? Didn't I day that. Thought I did.
Thanks for the pm's and sms'. I'll reply to all as soon as the box is apart.
Rest of you, feel free to keep stroking each other in my topic. :D
Buckna.
0427282562
:ninja:
Buckna.
0427282562
You guys are cute.
Rest of you, feel free to keep stroking each other in my topic. :ninja:
FAIL
Fail?
There where no noises when I drove it. And the person who owned it previously, drove it every track day and never had any issues with it, as you would assume. I've known the history of the car since it came from japan with this gearbox in it. I then purchased the car for a few bits I wanted for my s14, and am parting the rest out. So no, I never took the car to archy, and I never took the car to any track to drive it.
It was a track only gtr, couldn't exactly take it for a strap around the block.
:cool: Hoping to have box apart tomorrow.
http://www.flickr.com/photos/tweakedover/s...57624125014050/
there is some pics of the box, and a stock GTR box for you guys to compare it with :cheers:
If the box gets sent via courier anywhere, I would prefer to send the box as is now, pulled apart, with bellhousing seperate and all bolts etc in a secured taped bag, this way when the box arrives there will be not confusion as to whether the right part was sent, the gearset will be exposed and it would only take 15 minutes or so of work to put it all back together. Leaves everybody happier :yes:
as for the price. make me an offer, would be freighted on a small pallet, wrapped up securely, have forklift to load onto courier truck. Get a quote with whoever you please. We use fastway and couriers please at work, but can cater for any courier company.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
