Hey everyone, I thought id post up what I have done to my GTR over the past 5 years. Yes its been a slow build but its mostly done now. So this isnt really a progressive build thread as it happens .. its more how it happened. I plan to just enjoy it now and keep it well maintained. But we all know they are never finished so no doubt there will be more time and money spent.
Anyway this is what I started with...
http://s825.photobucket.com/albums/zz177/S...1394/The%20GTR/[/img]DSCF3136.jpg
1990 model which had about 75000 km's on an aftermarket Nismo 320 speedo. This car has always driven so tight with no rattles and the wear on original stering wheel and in other areas would suggest it hadnt done too many more k's then what was on the speedo.
The motor had been rebuilt some time before I bought it. It came with R34 N1 turbos, PFC, apexi cooler, some suspension mods, chromie wheels, and a fully sick stezza. It was way out of tune so that was fixed straight up and I had a rebuilt 33 gearbox put straight in with a OS twin plate clutch. It went well. Made about 270 rwkw at 18psi and ran an 11.9 at the creek.
Ok iam no mechanic but iam a tradesman painter. So this is where I put in the hard yards. Full bare metal respray in midnight purple. I really like this colour and I wanted to keep it a factory GTR colour. It was a big job but well worth the effort. Once stripped to bare metal we had a nice surprise. It was VERY straight with only a handfull of very minor repairs.
All 'eddged out' ready for colour.
the mask up
base coat on
2 coats of clear
and a 3rd coat!
straight from the spray booth
Ok its late. Heaps more to come. Yes the chromies go.
Tim.
https://www.sau.com.au/forums/topic/320793-my-32-gtr-build/
The bonnet was flow coated which means you put 2 or 3 coats of clear on it, bake it and let it cure for a few days then you give it a light rub back with fine sandpaper. Then it goes back in the spray booth and you hit it with one very wet coat of clear. This makes for nice deep gloss and a good finish.
more pics
This is what the bay use to look like. Note the air box . Little did I know how much power it was robbing me.
The cooler it came with. See the funky bar and plate design.
https://www.sau.com.au/forums/topic/320793-my-32-gtr-build/#findComment-5235899
The only other external mods I have done to date are N1 bumper vents, tinted windows and Work XD9 18x9 wheels. I think the bronze on the purple looks great.
This is basically what it looks like today
stopped at the gtr's drink of choice
Still have the full mechanical overhaul and lots of action pics to come.
Edited by R32 Zilla
https://www.sau.com.au/forums/topic/320793-my-32-gtr-build/#findComment-5235913
Even though i put a lot of time and effort into the body/paintwork of this car, my real interest in cars is performance. I have little interest in car shows id rather enter a hill climb or drag race it. I wanted to make this car really useable for all sorts of events and for it to be fun to drive on the street. The R34 N1's turbos did most things well. Really responsive for events like Texi and still managed an 11.6 @116 at the creek when I went back last year for another run. Before I did this run I got it tunned by Jim at CRD and it made 282 AWKW.
Texi in Canberra was really good. Wish they would bring it back. How cool was 'the back track' !! Anyway here are some pics from that event and one from the creek.
https://www.sau.com.au/forums/topic/320793-my-32-gtr-build/#findComment-5236608
Finally found some time to post up a bit more of this build. Late last year I decided it was time to do the motor. I was going to get the 26 I had rebuilt but things got a bit out of hand. I sold the old motor and gathered together some good parts. After a lot of research and phone calls I dropped the parts off at Dart Automotive for the motor to be built. The aim was to make it strong and reliable. Plenty of torque and it had to rev. With this in mind I went with a full Jun 2.7 stroker kit in an N1 block. Turbo choice wasnt hard. 2860-5's would be ideal for what I use the car for. I wasnt able to get photos of everything but I will post up what I have.
Tomei cam gears
Sard twin entry fuel rail
N1 block
Jun 2.7 crank fitted with ACL bearings . Yep its black.
10L sump and baffle
will post up some more tomorrow
https://www.sau.com.au/forums/topic/320793-my-32-gtr-build/#findComment-5266146
N1 water pump and Tomei oil pump were fitted
Found a head in good condition and it was then fully reconditioned. Jim fitted it with Tomei type B valve springs and new bronze exhaust guide inserts. It was also fitted with Grex 264/9.3 cams.
New -5's
HKS split dumps
Coming together now ...
Tomei metal gaskets
https://www.sau.com.au/forums/topic/320793-my-32-gtr-build/#findComment-5266661
Time to drop the R off. Out came the old motor and Jim started on the fuel system. We went with twin Walbros fitted in tank and new briaded lines. Sard fuel rail, Sard FPR and Sard 700's.
Ok some parts I havnt mentioned yet...
some of which i already had
Apexi PFC
Ross Balancer
Z32 AFM's
100mm intercooler
Hard pipe kit
40mm alloy radiator
tuned length stainless front pipes, high flow cat, HKS cat back system
Splitfire coils
Brand new OS Giken TS2CD clutch
Nismo clutch pivot ball
Nismo engine mounts
rebuilt 33 GTR gearbox
Turbosmart Eboost 2
Finally it was time to hit the dyno! Jim and I were both impressed with the result. It was done on a Mainline dyno which apparently read 10 to 20kw below a DD dyno which most cars are tunned on. I wasnt that interested in peak power anyway. If I wanted that then I could have easily gone a big single. I wanted good area under the curve and thats what I got!
This is at 24psi and according to jim a very safe tune.
Note the 300kw at 125kmph.
377 RWKW
https://www.sau.com.au/forums/topic/320793-my-32-gtr-build/#findComment-5266773
Very nice.I love midnight purple..
Has it been back to the track with the 2.7 engine ?
Yep it has been to the track but not your average one ..... I attended the Toyota Nationals in Dubbo at Easter this year. I have some good mates in the Toyota club and I have been out there for the weekend a few times. But this time I was able to have a go. I dont mind Toyotas. Infact the first car I moddified was a Ta22 Celica which i resprayed pearl green and fitted it with a 3T twincam turbo motor.
Yes it was a Toyota event but all cars are welcome and the event i entered (1/8th mile drags) was run by the Dubbo drag racing club and there were all sorts of cars there. There is also a show n shine and motorkhana on the same weekend. Its always a lot of fun and a very social weekend.
The drags are held at wellington airport and like all the events it was run very well. There were cars there from standard corollas through to 500kw supras and even a v8 altered rail. My car ran really well. I just need to chase down a miss it has which I think is from a lack of ignition/spark power. My best time was 7.2 @ 95.7mph with a 1.80 60'. This was good enough for 2nd outright! only loosing to the rail which which was running about 6 seconds flat. There were a number of 1JZ and 2JZ cars there running drag radials with decent power so I was happy to kick arse! Not bad for its first outing.
The car that got 3rd outright (quickest Toyota) belongs to my brother. He has an IS200 with a 2JZ and about 400 RWKW. Its the blue one.....
Here is a vid of my 7.2 run
more pics and vids to come!
https://www.sau.com.au/forums/topic/320793-my-32-gtr-build/#findComment-5270437
I really need to get some better pics of the engine bay....
A mates JZA70 Supra with big single ... does very good skids
Lined up at the end of the strip after a run
Me v 500kw supra
brothers IS200
Cool plates and a quick car.. 1J of course
https://www.sau.com.au/forums/topic/320793-my-32-gtr-build/#findComment-5275741
awsome 32 man, love the midnight purple with xd9s, similar to mine :P
howcome you didnt go the big offset with the wheels though?
I realise I could have got the 18x 10's now. When I bought mine they had just come out and there wasnt any that had been fitted to 32's. I was a bit worried about the offset sticking out and rubbing at the front inner guard. I am happy with the ones I have though. Can still fit 255's all round which is heaps of rubber.
https://www.sau.com.au/forums/topic/320793-my-32-gtr-build/#findComment-5286665
Ok so I plan to hit WSID in about 2 weeks and hopfully soon after that Ill have a go at Wakefield. Iam thinking I should run about 11.2 at about 120 - 125 mph. I would love to run a 10 but think I might fall just short. Has anyone run a 10 on standard -5's and street rubber ? I will be running 255 Federal RSR's on the rear (which are normally on front) and falken 452's on the front. All tyres are in good nic. Like I said i have already run 11.6 @116 before when i had 282 awkw and Ive run the 7.2 1/8th @96 with the new motor. Iam also a bit worried about breakages. From what I have read Iam just at the power where things may break like 3rd gear. Anyway ... thoughts/predictions ??
https://www.sau.com.au/forums/topic/320793-my-32-gtr-build/#findComment-5288513
  • 3 weeks later...
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
