hey i've got volk gt-c wheels 17x8 +28 at front and 17x9 +28 at rear and tryin to figure out what size tyres i need im only replacing the rear tyres atm cause front tyres are fine... Atm ive got 215,45,17 and there stretched heaps i was thinkin 235 x45x17 would that be a good size for the 17x9 or should i go like 255x40x17 .. also the wheels sit out side the guards at the rear not by much so im guessing i just have to roll the guards and get some rear camber arms to make them sit in side then i can lower it.?? and also i was thinking of gettin federal 595 ss tyres are they a good tyre?? any advice would be great thanks
https://www.sau.com.au/forums/topic/320825-what-size-tyres-should-i-get/
255's is the perfect size for a 9" wheel. If you've got 215's, they must be streeeeetched to within an inch of their life on a 9" rim :banana:
Make sure that you keep in mind the variance in overall diameter of your tyres as well as the ideal width for your wheels as the RTA doesnt look kindly on different O.D front to rear (your actually not even supposed to have wider tyres on the rear unless the vehicle came out of the factory like that, according to the RTA).
I would recommend:
17x8 = 225/45R17 - 634mm O.D
17x9 = 255/40R17 - 635mm O.D
You can usually go up to 255's on an 8" wheel but it's a bit too wide and you can go up to 275's on 9" but thats also a bit oversized.
Also remember that if you want maximum traction then you dont want stretched tyres... As for Federal 595's - they are a great 'bang for your buck' tyre, you'll get plenty of grip and life from them for a good price.
I hope this helps :D
depends what you want stretch or no stretch?
235 will be fine but if you dont really want stretch go 245 or 255.. too tuck the wheels in depending how far out they are lowering it with coilovers will naturally camber in a bit otherwise get camber arms
thanks bullet helped alot ,, alex they are about ahh say 2cm to 3 cm stickin out at stock height stock suspension do u think after lowering with coilovers would camer it in that much? or should i just see first then get arms / guard roll after i see
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
