Hey Guys,
Does anyone know of any places in Brisbane that do 4WD dynos and don't want testicles as payment? I want to get an at the wheels measurement of the power from my GTS4 so I know what I'm working with/towards for upgrades. I see a couple of places charging by the hour, but would it really take an hour to just to measure the power?
I would prefer Brisbane, but don't mind an hour or so drive if it saves me enough money. They don't even have to be an "import" garage, even just anyone who does custom fourbies that has a dyno. I don't need any tuning or anything like that done, just a simple power check.
https://www.sau.com.au/forums/topic/321042-needing-some-help-with-dyno-places/
Drop the drive shafts man and just get any normal dyno tuning house to do it. 4wd dyno's are an absolute rip. The read outs are the same as well. Confirmed this a couple of months ago when brandon got a dyno done. So fk 4wd dynos breh and save some money :)
No Idea on how much any of these charge, but these places all apparently have 4wd dynos. What you want is a "Power Run".
Advanced Performance Centre
2928 Logan Road, Underwood
Contact:Nic
Phone: (07) 3341 7223
Email: [email protected]
Website: www.apc-racing.com.au
Bob Romano Performance Motors
387 Lytton Road, Morningside
Contact: Chris
Phone: (07) 3395 8255
Website: www.bobromano.com.au
101 Motorsport
Unit 1 / 10 Judds Court, Slacks Creek
Contact: Grant
Phone: (07) 3209 5855
Website: www.101motorsport.com.au
999 Automotive
Unit 3 / 806 Beaudesert Road, Coopers Plains
Contact: Lochlan
Phone: (07) 3272 9992
Website: www.999automotive.com.au
Performance Injection Tuning Services
Unit 10 / 42 Export Drive
Molendinar QLD 4214
Australia
Phone : 0411 34 00 33
Matt Spry
+1
Matt Spry is probably the best tuner in brisbane, dont mess him around though make sure your car is 100% ready to run
Excellent, thanks to everyone for the suggestions! I wasn't aware that a rear wheel reading would be the same as an all wheels reading so that's a big help :ninja:
I thought over $100 and being charged by the hour seemed excessive. Now I know to ask for a power run. I have lots of phone calls to make now.
Thanks again for all your help everyone. Mods I have copied all these suggestions out, so you may feel free to close this thread if you need to.
Godzilla would be another recommendation.. in Tingalpa too.. he's now a sponsor on here so i would send him a PM and see what he says.. he installed and tuned my PFC originally so i also highly recommend him.. great bloke ... and you get to check out that sexxx of a 32GTR he's got...
oh, just a power run?
list your mods we can probably guess roughly what your pushing
Your guess is as good as mine on that one. This car keeps throwing out little treats every time the guys and I work on it. I was told it was completely stock, but that was BS. The latest puzzlement is the turbo, we have no idea what that is.
That's kind of why I want to run it and see what it puts out, to see just how unstock it is without pulling it apart.
if you take off the heat shield can you see the id tag? that would tell all
probs would make 170-180kw. what your aim?
bang for buck
- gtr inj
- fuel pump
- rb25 turbo
- dump / front
- intercooler
- nistune chipped ecu
stock ecu is limited around 200kw.
Edited by 32_Dave
yo
from what ive read over time im going to lock in an educated guess
i say 140-150kw as is (i havnt had a good look at your car in ages bro)
-exhaust
-pod
-fmic??
and then 170-185kw once all "bolt ons" are fitted and shes been tuned
-full 3" zorst
-pod
-fmic
-fuel pump
-rb25tubz
-dr drift (or ROM) ecu/nistune/emanage/adaptronic/etc
-ebc to 12-14psi
-gtr injectors
yeeeeww :P
let me know how it goes man! goodluck
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
