So I got my tint redone yesterday...20% all round ( not windscreen of course )
Am I the only one who didnt know I just voided my insurance? Found out from a neighbour who saw the car.
Ive always thought darker than legal tint could get me a fine ( was willing to risk it ) but Ive never heard anyone talk about it voiding insurance, therefore never even thought to ask anyone to "define legal tint"
If this is the case there alot ALOT of uninsured cars driving around!!
Prolly have to rip it off now do it 35% pffffffft !!
https://www.sau.com.au/forums/topic/321059-window-tint-and-insurance/
LOL anything that isnt road legal will "void your insurance"
however there are reasons why they would/wouldnt pay you out.. but i'm not in that area and am not willing to say anything due to it not being my area of expertise..
Yup. Insurance companies will try anything to get out of paying you if you need them too. Because it is darker than legal then your car is "unroadworthy" hence illegal so even if somebody stole your car and it was recovered the insurance company wont pay out. There are a lot of cars that fit in that bill and run the risk. I personally would rather it stay legal and forgo a little of the "look" factor.
You can get some tint that looks darker than legal but when tested comes up fine.
Edited by Kiwibob
Firstly, anything defectable 'could' be used to void your policy.
35% transmittance is the legal tint.
If you were at fault then hells yeah they would decline your ass. If you were not at fault they may let it slide but warn you about it, i know its how I roll.
If you don't change it please don't cry when you hit a car you couldn't see and have your claim declined =P
  • 1 month later...
Depends on the state - each state has different tinting laws. In South Australia you can't have more than 35% on any of the windows (and even that's relatively recent - it used to be 35% behind driver, only 70% for fronts - yuck).
Check with your relevant Roads/Transport authority website - they should have pretty clear rules about it.
And yes, as already stated - anything that's 'defectable' could void your insurance in a claim - given tint is a visibility thing, could easily by pointed at for particular accidents, and your insurance rendered void. Either way, you want to stay legal to avoid police attention and fines, right?
i got my old r34 GTT windows tinted to match the back and rear side windows the little ones (which i was told was not just tint but privacy glass or something..) i had them try to match the tint to the same colour which was apparently darker than legal.. didnt void my insurance but mayb i was just lucky...
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
