Hey guys,
I'm tossing up between these two tyres because Tempe have quoted me the same price for both tyres in 18 inch.
Any suggestions which way I should go?
Regards,
i could be wrong but i think the 452's are meant to be the more expensive tyre model and is available in larger sizes. both have similar reviews from what i can tell.
I've 912's on both the R33 and FTO. Nice long wearing tyre. Excellent wet handling.
My tyre guy said the 452's would be better if were going to trackdays.
I think they're a softer tyre so less life. Correct me if wrong.
Thanks for that mate! Yeh every one of the tyre guys have been telling me to get the 452's, but they also seem to be the only ones in stock. Both Tempe and 7 Day Wheels and Tyres seem to be out of it when I call up and ask if they have any.
How are the 912's in terms of ride? quiet? bumpy?
I got quoted $180 for the rears & fronts. Tempe said $180 each and 7 Day Wheels and Tyres said they would match it.
When my car was complied, I paid $250 each for the Fronts and $300 each for the rears, so they are great prices. The 452's are soft though, only got 20,000km out of the rears.
Has anyone seen prices like that in Brisbane?
Hi All,
How do the Falkens compare to Bridgestone RE001 tyres?
I would say they are both good grippy tyres in the dry. RE001's have a bit of a problem in the wet so reckon the fk452's would be better.
I am currently running RE050A's on my V and have read articles that test them as pretty much equal to the 452's but nearly double the price.
I also have a second set of wheels with an early Jap domestic market model of the RE001's and while great in the dry they are absolutely terrible in the wet. Make the stability control come on nearly every corner.
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
