Here's a weird one.
My r34 had a miss at several points between 4 and 5 grand under load. car has 68000 kms on it so i replaced the plugs with new iridium ones which seemed to fix it.
went on a trip to melbourne and... went fine down there but while there it did the same (no maybe similar). replaced the fuel filter to be sure but no change.
what it does now is fart around at high revs (over 5k). it spits and farts (i'm good with tech stuff) at high revs/loads and shits me right off. it got gradually worse so that now when overtaking I never use second (whereas before I would use it it to kick me from 90 to 120 when behind a gobbler) i only use 3rd. even in that gear i don't like revving it too much much cos above 4500 it gets that old miss again.
I am starting to think it's possibly heat related cos it's mainly happened on hot days after a fair amount of driving and earlier today i went for a drive and it didn't happen at all.
it sucks cos i feel like i have an engine that can only handle 4000 rpm..
I'm thinking coils but surely these suckers should last longer than 70k ???
any thoughts? (other than get your shit together you blubbering fool...) :hellpisd:
https://www.sau.com.au/forums/topic/32123-spark/
my R32 did that and found out that the 6th plug tip was almost burnt off due to lean mixtures. i installed a air/fuel ratio gauge in my car after that happened. when the car hits 5 grand the power dies off completly. it still accelerates but it has no power behind it.. i installed a 500hp fuel pump and changed the fuel filter and that still didn't do the trick... now i'm thinking it could be the fuel pressure regulator. anyone got any thoughts on it?
getting back to your prob. have a look at number 6 plug and see what the go is.
https://www.sau.com.au/forums/topic/32123-spark/#findComment-645492
Here's a weird one.
Had the same problem with mine ,took the plugs out regaped them to 0.8 .
I suspected the coil packs as well so I wrapped insulating tape around the stem of each pack, so if they were arcing across to the cylinder head it would stop them.
Anyway whatever the problem was plugs or coils it has fixed the problem.
I also took my Turbosmart BOV of the car and put the standard one back.The car would never run right with the Turbosmart BOV on,runs like a dream now.
https://www.sau.com.au/forums/topic/32123-spark/#findComment-645522
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
