If you're looking southeast then I've heard Dandenong Nissan are decent. Only 15 mins or so from Cheltenham/Mentone area. Having spoken to their service and parts departments before, their guys seemed familiar with the car at least unlike a couple of other dealers who didn't even know the car is NA.
I got mine serviced at City Nissan in North Melbourne because I work in the city and I was pretty happy with what they did including replacing the drive belts for a reasonable price.
+1 for Dandenong Nissan. They always do a great job on my car and keep the price reasonable.
cool, thanks guys - Dandenong sounds the place to go! Anyone in particular to speak to, or just the front desk?
I dont understand why people have recommended a Nissan dealer.
I would only ever go to Nissan as a last resort.
I went for City Nissan for the first two services, include a major on 80,000 with CVT flush. They've done an awesome jobs.
Then I went to M1Motor in Nunawading last time as recommended by friend (too lazy to go from Doncaster to City during holiday),
got my rocker cover fixed and got my car back after 5days (they promised 2 days). Price was okay after their "half price discount", but the service was total disaster compare to Nissan dealer.
Price vs Quality/Services....I'll go for quality and service for sure for my beloved V
.. so agree with you :rofl:
If you can go a little more to the east,
I Revolution would be the wkshop for V35, they are in Bayswater now.
Why's that?... I've only had good experiences with Dande Nissan with my old R33 and now my V35.
I can't say that about some of the "specialist" workshops I've been too. :)
Bayswater is way too far for me - even Dandenong is pushing it. I regularly pass a place in White St Mordialloc called"8T8" or something like that, that always has a few R33's etc sitting outside, occasionally a stagea, but never seen a V35 there.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
