Hey guy's
I have a B&M pro ratchet shifter with pretty much evrything u need to go into and auto r33 skyline..
(pics avalible on request) ... $ 180.00
I also hav a fiber glass Nismo lip for a r33 gts-t ser2 std frount bar ( has sum reparible damage underneith will need re-spray ) currently lite silver ... $ 50.00
Located in Melbournes s.e. suburbs
https://www.sau.com.au/forums/topic/321469-bm-shifter-and-nismo-lip/
never used one of those shifter lol they rad
There pretty good, just more controle over the auto really.. best if u have the auto set up to be fully manuleised i had it in my old 33 with a bit of power great funn :P
Sorry i cant send anymore pm's atm...
Consider the nismo lip SOLD unless i hear otherwise
(if its bak on the market ill let everyone know a.s.a.p)
Thanx very much..
  • 3 years later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
