Hi all,
I've got a faulty "ECR33" Power FC, just been diagnosed with a water damage. :P
Every function works except for the one that controls the injectors. :)
I've been told if I can get the chip (5D4T313-151007) replaced, should work as usual.
I'm aimming to find out if there's any interchangeable chip available before sending it back to Japan via Nengun ($14,000 JPY to reset the PFC, + shipping cost to Japan and back + additional repair fees) :D , so if people who have Power FCs can please help me find out whether you have this chip in your Power FCs will be wonderful.
Hopefully most Power FCs share the same design and chips.
Thank you all for your time. :D
Red box shows the location of the chip in my Power FC.
most of the r33 get a faulty main processor which is the large one in the socket. The reason r33 powerfc's were discontinued was because that eprom was discontinued and is impossible to replace... so if that main processor is kaput then the powrfc is not repairable.
I repair about 4 or 5 owerfc's a week and unfortunately most of the r33 ones have a dodgy main processor and it cant be replaced as it is no longer in production.
It seems to be only a r33 issue most other pfc's just have dodgy capacitors or igintion transistors.
Only a handfull of PFC's run that large processor (all now discontinued by apex) it is not common across the whole range. Those whithout this processor are still available new.
Hi all,
Every function works except for the one that controls the injectors. :(
I'm aimming to find out if there's any interchangeable chip available before sending it back to Japan via Nengun ($14,000 JPY to reset the PFC, + shipping cost to Japan and back + additional repair fees) :) , so if people who have Power FCs can please help me find out whether you have this chip in your Power FCs will be wonderful.
Thank you all for your time. :(
Ah shizzer i just looked at your picture, i have a few spare of those little suckers (i thought it was the usual main cpu failure).
If you like i can repair it here if you get stuck.
  • 2 years later...
http://www.ebay.com/...=item19d537ec9d
take a look at the IC chip it is the same. but IC 15 is the igntion driver and you should have no spark when this is bad. a good test is to pull all the coils off and put plugs in them them remove cas sensor, then with the ignition turned on turn. then turn the cas sensor clock wise slowly this will simulate starting the motor, you should hear the fuel pump prime and injectors fire, but no spark. i can fix it for you if you like, and test it. Please send PM if you still alive. lol
Edited by MJTru
only the first batch for the first 2 yesrs were like you say then they fixed it,but didn't want to be liable so they pulled out. that is the truth, i can provide manufacturing dates of bad batch if you really need it.
wow. i dont think that was the topic. here are some good link to doing it your self. thanks to John Sobon
http://www.sparkfun.com/tutorials/96
you can do it just buy the chip.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
