AUSTRALIA - QLD
EFI Performance
Unit 3/15 Emeri St Stapylton 4207
Contact Rick on (07) 3801 80 75
rick.w [at] efiperformance.com.au
http://www.efiperformance.com.au
East Coast Customs
2/14 Boothby Street, Kedron, QLD
Contact Rob on (07) 3359 5466
info [at] eccustoms.com
http://www.eccustoms.com
Fabians Mechanical
Shed 2, 29 Hyne St, Gympie, QLD
Contact Graham at mech [at ]fabian.net.au
http://www.fabian.net.au
K-Tune
5/8 John Duncan Court, Varsity Lakes, Gold Coast, QLD 4227
Contact Keith on (07) 55221115
http://www.k-tune.com.au
Mercury Motorsport
Unit 2/278 Newmarket Road, Wilston, QLD
Ph 1300 558 650 / 07 3352 3363
Contact Trent at sales [at] mercurymotorsport.com.au
http://www.mercurymotorsport.com.au
Stu Cornall Tuning Services
48 Old Maryborough Road, Pialba, QLD
Ph 0411 260 656 24hrs 7days
skyline_stu [at] optusnet.com.au
Available to NIStune ALL over Queensland. Extensive Nissan ECU tuning experience
www.nistune.com
Gympie nistune is a no-go atm. He is now in Dalby with no dyno as of yet and i'm unsure if he is getting another one.
gary who used to work for him (and did most of the tuning) would still be able to do it. he opened his own workshop after graham shut his down. he bought a dyno dynamics dyno and i think he still has a few spare licences left to tune some cars with. he's shutting down in a few weeks though, but he will still have his dyno.
do you have his phone number? I got told from another nistune dealer is they cant do r33 's with out putting a r32 ecu in can anyone verify that? seems a bit strange
to do the r33 you either have to use a z32 ecu or r32 ecu (can't put a nistune into a r33 ecu). the r32 ecu won't allow the use of vct, however the power difference with and without it is minimal. when gary was playing around with his ceffy (has rb25det in it) he found that there was only a few hp difference between having it on and off.
his workshop is called gympie roadworthy and mechanical centre. phone number is 54829477. tell him marc sent you..... on second thoughts, maybe don't tell him that. he might double the price, LOL.
yeah gary told me. i might try and drop in
I rang gary and told him i cant make it , my controller stopped working and when i pulled it apart one of the resistors which feed the hand controller for my digital fuel adjuster had smoked it self. Im hopping it just because it was resting on a heat sink ( fingers crossed ) can u believe no where in kingaroy sell resistors on the week end dick smith are not stocking them anymore and anything jaycar is online
i ended up finding a few resistors in my mates old buggered alpine v12 amp. i installed them and it did it again bugger!!!! i have ended up removing the ecu and giving it to toshi ( from this site ) to retune but once done ill head over there and get the car dynoed to see what power it putting out and also that its not running too lean after the tune.
  • 3 weeks later...
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
