as it says i have a near new ross harmonic balancer was fitted to my rb20 engine then didnt use it only wanting $200 for it. pick up only sydney any questions or to organise pick up call me on 0431314714 cheers james
https://www.sau.com.au/forums/topic/321565-rb20-ross-harmonic-balancer/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
