when is your shipment coming in for the gtr wing and do you have a white one
Should be here mid April.
Not sure if I have a white one, but that is easy to change...
I have a mate who makes perfect FBG copies if that helps, give me a call.
Thanks
Adam
0412631081
  • Replies 48
Any chance of getting my drivers seat clips, the ones that hold the map pocket on to the back of the drivers seat, four [i'll take more for next time if possible] of them, in a '98 SII gts2.5t. Or a complete map pocket if thats how it comes.
Houdy,
Can organise as many GTR wings as needed. Looking at about 500 for a primed one plus postage / freight to anywhere. These wings are excellent will not disappoint.
get in touch with Adam (supahiro27) or myself,
Haro
[email protected]
[email protected]
Hi Sven Laptop
PM sent to you.
Hi ASH (couldn't find the squiggly thing for your S :( )
Yes we can do the nismo wing for the 33s no worries. As for the blade alternatives.....sure can mate, we have already done a carbon one (looks sexy) , twin blade alloy shouldn't be a problem. The 500 for the GTR wing is an approximate price at the moment and does NOT include any freight or postage.
Feel free to send me an email with any other questions.
Cheers for the interest.
Haro
[email protected]
[email protected]
I am looking for a r33 speedometer or complete instrument unit if you can help
Hi SXE33,
Sorry for the delayed reply, YES we do have a complete instrument unit found it this arvo!! :stupid:
It is from an R33 GTS-t i cant remember what kms it is up to, it is in good condition.
Im not too sure on the "going rate" for these things so please PM me with a decent offer and we will see how we go. (I can probably bring it to the Servo some time this weekend so if your in the area you can have a look, get back to me on that.)
Haro
[email protected]
[email protected]
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
