Hey guys,
I've done a search but didn't really find an answer to my question...
I'm currently looking for an ECU for my R34 GTT, and the options i've narrowed it down to are PowerFC, Nistune, and an ECU i have only recently discovered, Adaptronic.
My preferred option would be a PowerFC, but they are very rare for R34's, and the absolute maximum i would pay for one would be $1300 with hand controller. So i will keep my eye out for one right up until i purchase an ecu, but i have all but ruled out finding one completely.
Now i had pretty much decided to go with Nistune as AllStar Garage quoted me $950 fitted and tuned, which seems like a good price. But then i discovered the Adaptronic e420c ecu, which from what i have read about it, seems like quite a good computer. This is the website: http://adaptronic.com.au/products/e420c.html
Can anyone tell me a little bit more about the e420c and what all it can do, and how it compares to how good Nistune is and what Nistune can do?
https://www.sau.com.au/forums/topic/321640-adaptronic-e420c-vs-nistune/
what do your local tuners use and support (and can tune?)
no point getting a MOTEC if no one around you can tune it or they will charge $2k to tune it
likewise with any ECU option, even the powerfc or adaptronic - they are useless if your local tuners cant do tune it or charge through the ass to tune it
my pref is powerfc (see my sig for powerfc faq and online hand controller emulator)
for your car i would go nistune but if you want a cheap adaptronic i have one here;
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...=STRK:MESELX:IT
the new E1280s is a real work of art and would embarass many of the better known ecu's around.
AllStar Garage are my preferred tuners, they are incredible with most ECU's.
At this stage i am leaning towards the Nistune because i know AllStar are great with them, and i know a lot more about them. I just wanted to find out more about Adaptronic because the unit is around the same price of a fitted and tuned Nistune, which isn't bad. If it is a better unit than Nistune then i would like to look into it more, but if not than i'll continue looking for a PFC or go for a Nistune.
That will work on a Series 1 RB25det?
How much for tuning on top of the end price?
Also, which Z32 ECU is best for a Nistune? Does it really matter?
Seconding this, does it matter much which z32 ecu is used? 41p04 was labeled as preferred in another thread but i just wonder why
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
