So i got rid of my Maxima and replaced it with this bad boy. For the price it was going for, its condition and the options it has, I couldn't say no.
Its an 89 model, RB20E Auto, 76xxx kms seem genuine.
Panels are all good bar one (pending fix), the paint is shit especially on the bumpers and there's a few spots of rust.
Runs mint though, has been looked after really well, the air con still works.
Needed to pick myself up a nice car to cruise around in. Having a work car is awesome, but a manual hilux with radio only certainly never fits when you want to go for a drive late at night or on the weekend.
Options include:
Factory sunroof w/ shade + logo
ABS (unusual for pre - xNA31s)
Optional fabric interior (still pretty bleh, but better than standard)
Extra bling lining down the doors.
I don't care what you say - I like it :P
Edited by Nic_A31
https://www.sau.com.au/forums/topic/321677-my-other-new-ceffy/
Haha a few people have said the same thing...
The sunroof made my first one more appealing to purchase, and I aquired this one by posting a WTB for a Cefiro rolling shell when I was paranoid about the other one being bent...guy messaged me said he had one with a sunroof already, perfect win.
Aye lads, I be holding a proposition for ye,
How about these rim for the boat
Couple of hundred, and about 800 by the time its set sail across the seven sea's and landed at my door.
DO EEEET!!!
I have replicas of these and they look fantastic with the right offset. Pity mine isn't lowered.
I think Dan should sell me his jap dishies, since they've been in his signature for soo long:
haha, so true :yes:
also spacers are for pus-sies, those stich type meshies need more lip on the rear for the goods
check ns.com vip rims are usually floating around
Aquired R32 4 pot calipers, slotted rotors (multi stud pattern), Standard R33 rotors, R33 calipers and R34 5 stud rear hubs w/ bearings.
Pending brake lines and rego before they go on, I test fitted the front calipers with the stockies and 3mm slip on spacers.
IT CLEARS....JUST. The rim somehow free-spins without grinding...but have a look at this pic, Definately not going to risk it, there'd be less than a 0.25mm clearance in there....need bigger spacers or different rims, or wait till I turn the front 5 stud .... but since i got multistud rotors, I can retain 4 stud and just use some slip on spacers in the mean time.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
