both bumpers are in pretty shit shape, I'm gonna throw the factory bumpers on, from my project Ceffy
IMO these look better anyway, with the two vents to the side, rather than one big opening.
http://www.skylinesaustralia.com/forums/up...-1247910577.jpg
Nooo. I painted up the other one today in Nissan 362 (crystal/arctic white), looks good painted white.
i think it'll look better with an auto trans fluid cooler off to the side :P, the other one is also longer at the lip and flares out more. :)
  • 3 weeks later...
Halfway through manual swap.
Now has black interior, the chord type stuff called "modern" in the brochures
Series 2/3 taillights fitted.
Pending hubs and brakes before it gets the R33 GTR 17"s on.
Just wish it was going, for skids, cruising and new job :thumbsup:
Edited by Nic_A31
Nic - looking buttery man, can't wait to see it with the S3 bumper :woot:
word of advice but - i see you have the same "door bump protectors" that i have - the white strips that run along the centre of the the doors... that are no longer "white" as they are turning that funny "poo / pink" colour
^^^this stuff here - from bunnings and about $6 for a whole box... steel wool (mild steel)
pinch a bit off, dunk it in some water, and scrub away - don't go too rough though!!! the product will work it's own magic :laugh:
gets them looking brand new like mine :) (these bump strips were the fkn BANE of my existence till a few months ago!!!)
I used to get soooooooooooo annoyed cos my car would be that "fresH" arctic white with mirror like paint - but those strips would forever be this orangey bore water stained pinkish brown yuckyuck.
so get some and get that bit clean! it changes the look of the whole car - trust me! :D
Thanks dude....yeah they're alot worse than what they look like in this pic....they look atleast close to the paint because of the bright work light but in the flesh they're turning yellow, badly. I was thinking of painting them black, to match the strips (on the same level) on the bumpers...but will try that first.
Yeah I had a slight finger malfunction there.
My bad.
Nic got the engine from KYP, without the loom. Which should kinda NOT happen considering the computer needs to go with the engine.
f**kers.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
