  • Replies 174
aahhh, don't ask dude.
we were having disputes with the trubo supplier and when we came to an agreement, the dude from garrett said that he'll send down a A/R .82 which should be fine, but they actually sent down the A/R .63, and before i knew it, it was already on the car.
i think it should be ok though as the same combo with a A/R .63 made ~260rwkw on an RB30ET at ~20psi.
if i'm not happy, i'll be sending it back to sydney and asking for a .82.
That was a little bit of interesting information. Interesting being the amount of extra boost required for the SOHC head on the 3ltr to make 260rwkw.
you're cool dude.
i actually found out from my friend yesterday that the car i mentioned actually ran 18-19psi when it made that power.
also, another car with that same turbo made 285rwkw on 24psi.
i guess the SOHC makes quite a difference to power as compared to DOHC.
actually, my 2L cossie engine (DOHC) made almost the same power a VL RB30ET (SOHC) would make with the same turbo on the same boost, so i'm happy.
btw, the VL i mentioned which made ~260rwkw with the GT3040 (A/R .63) has run an 11.67@115mph at calder park, and fyi, it's a 5 spd manual.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
