Hey Guys
looking for a set of cams type b 260 and a set of cam gears so far the cheapest ive found is $1270 for the lot, can anyone match this?
cheers guys
Edited by Hiroshima Screamer
https://www.sau.com.au/forums/topic/322036-wanted-tomei-poncams-and-cam-gears/
Hey man,
look at: www.perfectrun.com.au or even www.rhdjapan.com
both sell at really cheap prices direct from Japan.
Hope that helps.
i think we have a winner , thanks mate.... have you bought from perfect run before?
Yeah I have purchased from Perfectrun previously - top notch - have got coilpacks and also recently bought HKS cam gears - cheap enough and even postage is reasonable considering it is coming direct from Japan.
I am actually looking at buying Poncams myself in the near future and Perfectrun will be my first stop.
:domokun:
nice.. what was the freight time like?
Freight time was really good, once all payments have been processed the item(s) are sent out straight away, and they usually give a tracking code so you can keep tabs on where it all is - from memory it took no longer than about 10 - 14 days.
Honestly can't wrong, If your willing to wait that little bit extra for delivery direct from Japan it will always work out cheaper than buying locally.
  • 1 month later...
Sorry to revive the thread, but, those prices listed on Perfectrun, are they for a Pair of camshafts or are they for each camshaft? Thinking of buying a pair of camshafts and pair of cam gears/pulleys for the GT-T
The prices listed on Perfectrun are for a pair of Camshafts.
Their prices are slightly higher than usual at the moment due to the crappy Yen to Dollar rate.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
