Hi everyone,
I've got a set of 17" RJR Zenith wheels + tyres for sale.
Specs:
Pretty sure they are an offset of +38 and 7 inch wide(all round).
They are in exceptional condition with no gutter rash or scratches whatsoever. Wheels will come with 225/45/17 Maxxis MA-Z1 tyres with 85% tread all round. Been on car for around a year and always looked after and washed regularly to maintain condition.
There is only one downside; there is slight peeling inside 1 or 2 spokes on the rear right wheel only, however is almost un-noticeable.
Heres some recent pictures:
Pricewise, Im looking for around $800. Negotiable and any offer considered.
Im willing to send interstate at buyers expense too. Any questions dont hesitate to contact me on *number removed*
Cheers, Ron
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
