Got the car back today, pulled 287kw @ 18psi, full boost around 4000/4100rpm range according to the dyno sheet.
Only drove the car for the 10 min drive home, and it pulls hard on boost. Will give it a good run over the weekend to see whats what, and will post up the dyno graph hopefully tomorrow :D
Cheers mate,
Low boost @14psi is still through the EBC, which is a Greddy Profec Bspec 2.
The cam gears were pretty much left untouched from the original tune with the std turbos which was response. The settings that i can read (through the clear cam cover) look like:
- about 2-3deg adv. on intake side and about 2deg ret. on exhaust side (which is a bit hard to read because of the CAS being in the way).
Been for a couple of runs to the shops and the car is still very responsive. Would be hard to beat in the hills I reckon lol.
Though the real boost doesn't come on til around the 4k mark (up about 300-400 on std turbos), the car is still much quicker while its coming onto boost than it ever was, and its really pulling hard at about 5K all the way through the revs. So you could say the car is now quicker everywhere through the revs.
The -9's seem to be an almost perfect match to the revvy nature of the RB26 when compared to the std "choke" turbos.
Yea I agree with it being quicker coming into boost. As I shown above I got it to basically the same level of boost at the same rpm but it actually feels better than the stocks coming into boost
Today I disconnected the signal going to the acts and it showed that these babies are capable of 18psi at around 4k hence why i asked about your cam gear settings as I feel there might have some gain to be had there still.
What boost are you seeing with the ebc off? I have the 8.8psi acts so I'm trying to get the best response I can with them by adjusting preload and then i would interfere with the ebc. Did you adj prelaod on yours btw?
Mine are the 1 bar actuators but I haven't driven it with the EBC off.
I set the preload just by adjusting the rod until it freely slid onto the pin then turned the adjustment in 6 half turns so the rod needed to be pulled onto the pin with a bit of effort. Do you think there is much to be had by adjusting them anymore than that? what was your initial preload and how much adjustment has been required to show the results you have got?
When I got mine the section of the hole towards the end of the rod was sitting on the middle of the pin on the wasteagate flap. I tightened it in 2 complete turns and it now sits almost to the edge of the pin.....a little effort to go on but nothing hard to do, and I noticed the oem turbs had about the same preload too as I have them on now.
I will continue to fiddle with them as it only takes me about 10mins to adjust....the hardest part is letting it cool down. I will post the results
The 2-3degs you mentioned,..... Is it actually 2-3 notches on the cam gear?.. If so, it will actually be 4-6degs as 1 notch is equal to 2 degs
  • 2 months later...
mine is hitting 18psi at 3800rpm, cam gears adjusted, unknown cams
seems like mine is hitting 25psi around 3800-4000 RPM
with standard cam gears!
will put up a final power figure in this thread once all its issues are sorted!
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
