Thanks guys,anyone run 300kw with -5s on a 1/4 mile with a time?
No one would buy -5s and run 300rwkw. Added lag for... What?
They are 360rwkw+ turbo, so you run them at 360rwkw... OR buy -7s if you want 300rwkw, or -9s if you want 330rwkw
Given that is what 7 pages of this thread is about, not to mention the other threads...
I understand the lag on the -5s but i was more wanting to know 1/4 miles times both -5 -9 running at 300kw.
The reason i ask is im running a stock bottem end and slowly building a motor to run 380plus kw and i dont want to buy -9 or -7 for 300kw an selling it of 1 year later for half the price,i do want to swap the -5 on to the new built motor chance its completed,there are numbers of people running 300kw even less on -5s,im on a very strict budget,and dont mine the lagg to save some $$
Edited by nitestage32
Not sure, maybe you missed this?
It'll be about the same. 300kw is 300kw.
Torque also plays a factor but for the most part it'll be close enough for the sake of the argument.
Same shit dude. It's not an issue of importance or one you will EVER get an answer to.
Car weight, driver, tyres etc - all far more important variables to worry about anyway.
Oh and if you are on a strict budget, hate to tell you but you'll end up blowing it. No-one meets a tight budget when doing a full build. It's just impossible as there are too many variables that again come into play.
will be going for the -5, pushing 300kw,No one is saying im putting chinese stuff on my other built motor,i was relating to the turbos that is where i can save money on,cos i do want to get 380kw out of the new built motor.
I don't get your point for, sounds like you want -5's just so you can say you have them, if you don't mind the lag why not aim for 400kw? If not go smaller. Your desicion is 300kw lagy or 300kw responsive....simple choice
He is slowly building his motor so running 300kw's with the -5's for now, and then when the motor is finished being built he will go for a higher figure :thumbsup:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
