arc air box for sale
only used for about 2000kms i bought it brand new from nengun for around $700
these absolutlely shit on pod filter set ups and standard air boxes
u feel the extra response the whole way thru the rev range
only reason im selling is because i am going a 26/30 with a gt42r and going with a bellmouth
also never had a problem with cops with it compared to covered up pod filters.
$500
dont low ball me stupid offers they will be disregarded.
pm me ur offers
https://www.sau.com.au/forums/topic/323034-arc-air-box-for-r34-gtt/
lol
yeah mate it is cleary secured in my engine bay, they dont come with piping it bolts onto ur afm
ill supply everything that it came with
easy as f**k to install as well
bump
Edited by GUN_METAL_GTR32
i've got a return flow fmic on my r34, would this get sufficient intake without a snorkel (or does it come with a snorkel?)
hows this with heat soak?
any kind of induction sound through it?
hay mate
i dont know how the piping works on a return flow style cooler so i cant answer
its fine with heat soak, i had a cold air intake from the front bumper to underneath it and i reckon that kept it nice and cool
the induction sound is different to a pod and different to a oem airbox i cant really describe it but its tough
u definately feel more response thru the hole rev range
im only getting rid of it because it wont suit my gt42r with a bellmouth on it
if ur in melbourne u can come and have a trial fit if u please
japmuscle i apologize for my post
I would have def been interested in this, however from what I have read these are defect-able ? (or are they ok)
My car goes in for its EPA test this week and I have only had it a few months, and yes it was a "random" breath test..
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
