  • Replies 67
Posted Images
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
Don't want to have to deal with reregistering it/insurance and moving with it
will Take 15k if i can find a keen buyer
I am in the market looking for a clean R32gtr
I have an N14 Pulsar 5speed man with a bazillion Kms on the clock with 12months reg and kick ass air con, wicked run around plus mucho moolar ontop if you are interested?
PM me I would like to talk about the gtr with or without the Pulsar trade,
Cheers
  • 4 weeks later...
Hi all,
I went and inspected this car last Tuesday (18 Jan 2011) , and I probably would've bought it except that on the following Friday I was offered a new job on a much higher salary and as such I am now looking for an R34 GT-R. Nevertheless, I thought I'd post my thoughts on Matt's car.
* Body is straight. I checked all the weld points for signs of damage/repair;— couldn't find any.
* I ran a magnet around the body of the car to check for bog. Magnet did not fall off at any point. (I was quite surprised, no other R32 I've inspected passed this test!)
* Paint is 99% flawless. Only blemish was a minor scratch on the passenger side of the front bumper, no physical damage to the bumper/body.
* All the electrics work. Windows are smooth. Car idles/revs smoothly.
* Engine did not blow any smoke.
* Interior is in good condition. No bubble in the dash and the driver's seat bolster showed almost no wear.
* Some slight surface rust in the spare-tyre well. I inspected this thoroughly, it is only SLIGHT surface rust at this stage and has not moved into the metal. Would only require a light sanding to remove it. Otherwise you could just keep it garaged and it wouldn't get any worse.
* Under-chassis was clear of rust.
* Matt had the car idling for 15 minutes, I checked for oil/coolant leaks. Couldn't find any. Got under the car with a flashlight and ran my hands all under the engine/around the sump checking for leaks. Only thing I got was dirt on my hands. No oil leaks found.
Overall, it's definitely one of the better R32s I've inspected. And as I said, I'd probably have it in my garage right now if I wasn't offered this new job.
If I get time later over the weekend I'll post some photos I took of the car.
I wish Matt all the best with selling this car.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
