Hey guys,
I recently just bought a 12" Alpine Type S sub (SWS-1223D)
Now, I need to buy an amp for it.
Its rated at
900W peak and 300W RMS
Impedance: 2ohms + 2ohms
So, being a noob and all, I needa know what exactly I need to look for in an amp. All I know so far is to look for a monoblock amp. What sort of power should I be looking for that would be suitable for this sub?
A friend of mine said its better to overpower your sub rather than underpower it?
Any help would be much appreciated
https://www.sau.com.au/forums/topic/323805-amplifier-selection/
I've got that same sub in my complete Alpine R series set up but im running it all on the one amp crossed over, the amp im using is MRP-F600 which is 1320W max.
Hope that info is at all helpful, but im sure that people with a lot more experience will give you more info on a proper mono amp suggestion, just thought the 1320W Max spec would help with an indication of how overpowering is what they did with mine.
are you brand loyal ?
you don't need a mono, you can use a 1,2,4 channel amp depending on the amps load handling, I use 4 channel bridged x2 into a 1 ohm load on my subs but only to reuse some old stuff I had lying around until sponsors supply the amps in my car
too much power is better then not enough its called "headroom" more headroom less distortion, in the right sub box of course
but some amps can hammer your charging system bad, so you need to take that into account as well ?
do you like music loud ?
what kind of music?
do you plan on competing in SQ or SQL, testing ? sound offs ?
do you want a show off amp or hidden?
what kinda head unit do you have ? does it have outputs for sub x over?
to tell you the right thing, you have to take this and more into consideration to make the right decision ?
what kind of music?
yea loud music is nice, well Id like the option of having it fairly loud.
I listen to pretty much everything from heavy metal to rnb to trance.
I dont plan on entering competitions, this is just for my enjoyment :thumbsup:
not too fussed about showing the amp off, pretty sure its just gona be attached to a box sitting in my boot
I have an alpine CDA 9886, http://support.alpine-usa.com/products/doc...OM_CDA-9886.PDF thats the owners manual, it has an extra sub output thingo.
lastly, I typically stick more known brands, but dunno if Id say Im loyal to any in particular
a reasonable brand 600w mono amp should do for your type-s. But if you can, id suggest you get something around 1000w and run it around 400w so your not stressing the amp so much plus you can always upgrade your sub in the future and the amp will still be able to handle the new one giving that its only a little bit more powerfull.
I dont plan on entering competitions, this is just for my enjoyment :P
what car is it going in ?
how much room do you care to waste, spare tyre intacted still ?
going in an r33 so the boot space is already pretty limited lol
already got the sub and box and thats gonna take up a fair chunk of the space. I was told I can mount another amp on top of my other one which is near the battery or I can just put it on the back of the box.
I couldnt edit this so Ill just add onto it here...
forgot to mention that the spare wheel is still there and will stay, mainly cause my dad is a bit of a safety nut and will complain if I take it out lol
he's still confused as to why I had to go buy a skyline hoon-mobil haha
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
