SELLING IT ON BEHALF OF A MATE
GREAT FOR CLEARING DEFECTS + RWC. ESPECIALLY THE WAY THE COPS ARE GOING THESE DAYS
HARD TO FIND.
In good nick, nothing broken all clamps & rubbers in place.
Pick up from Taylors Lakes (MELB)
Price: $180
Can Post All around AUS for an additional $25
MOB: 0422756270
CHEERS
Edited by G4orce
https://www.sau.com.au/forums/topic/323846-r32-rb20det-stock-airbox/
