Im trying to figure out 100% of what is involved in this....what are the downsides, besides warming up i presume? i want to get rid of that whole tangle of pipes...im positive i have seen it done on here somewhere but i cannot remember where...
Can anyone list exactly what is involved...once it is removed...(old piping etc)
Im going to run a remote filter relocation kit + aftermarket oil cooler...so i would like to run a plate straight off the block ---> filter ---> cooler.
(i hope this makes sense :>)
Cheers
Aiden
done this just last weekend.
you just unbolt the hoses, undo the 4 bolts around the mount (helps to have the oil filter off) once all the bolts are out gently tap the mount off.
once its off you will need to take off the oil pressure sender cause the rb20 mount doesnt have spot for it but about 5-10cms back and slight up from the oil filter is a 1/8 bung in the block thats tapped into the oil gallery thats where you put your sender. there is a casting close to the hole thats where the adapter is needed to space it off.
i didnt have heater hoses hooked up due to custom plenum, after market cooler and relocation kit but you just add a joiner in to loop the two hoses together.
Parts needed,
Rb20 stock oil filter mount
Nissan 4 bolt gasket that joins the block to housing
Inner o-ring on the inside of mount.
A joiner to join the two water hoses together.
A adapter for the oil pressure switch size 1/8 x 1/8 x 1 1/2 or enzed p/n A72-020224
Thread tape
Oil to top it up (best to do job when servicing anyway)
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
