if you wanna turbo a stock rb30e then ive been told to get a rb30e from a vl series II as it already had the water and oil lines on the block. Theres a thread in the N/A section covering this topic already, I think someone got an rb30e from a VL and turbo'd it for a his r33, not 100% sure
https://www.sau.com.au/forums/topic/32407-rb30et/#findComment-651703
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
