As far as I know it's fine becuase your trying to keep the overall circumfrence the same but the rear is wider so it has to have a smaller sidewall.
Click here for a tyre calculator to help you see what happens when you put the same profile on both front and rears. Just type in your front and rear tyre sizes and see the difference.
https://www.sau.com.au/forums/topic/32408-tyre-question/#findComment-650566
yes it is fine, because the 40 or 45 rating is just an indication of a ratio of the height of the tyre wall compared to the width of the tyre. So obviously if 235:45 and 255:40 mean that the tyre heights will be similar. if both the tyres were the same then the ratio would mean that one tyre had a definetly higher side wall.
i have the same tyre sizes as you btw, and they are fine.
https://www.sau.com.au/forums/topic/32408-tyre-question/#findComment-650775
Thats an excellent site, thanks.
https://www.sau.com.au/forums/topic/32408-tyre-question/#findComment-650790
i have the same setup, 245/45/17 on the front and 255/40/17 on the back and have no worries. Just dont do what i did and get ripped off for a pair of bridgy S03's 255/40/17 ($450 ea.) I thought he quoted me the price on the pair - not each. :bonk:
https://www.sau.com.au/forums/topic/32408-tyre-question/#findComment-654032
s03s are a good tyre though.. good tyres = pricey. especially huge sizes like 255s.
i just got a set of pirelli p6000s,, 255/40/zr17 for $90 each.
catch= second hand. one was at least 95% there.. the other was 30% gone on one side and 50% in the middle(done care about that part too much :D so yeah had to make sure the new edge of that one was on the inside.
but still. it would have cost me double 180 to get just one good new tyre. so even if i use them for half as long its good value :)
https://www.sau.com.au/forums/topic/32408-tyre-question/#findComment-659599
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
