I have a full set of black Brembos and rotors for sale if anyone is interested before I put them on Ebay. I am looking for around the $1500 mark which seems to be the going rate.
They worked fine when removed and the paint/stickers are in average condition.
I am looking for the following items for a R32 GTR if someone has them to trade as part payment on the above?
- Greddy under drive pulley set
- PWR or similar performance alloy radiator
- fuel surge tank set up
- set of standard Nissan GTR calipers
i have a set of standard r32 gtr brakes on my car, would u be willing to do a trade + money your way and would 33gtr brembos bolt sraight on 32gtr?
Hi Andrew,
I have a spare set of R32 GTR rotors and brake lines etc so I would only be interested in your stock calipers. I would knock $600 of the price for your calipers as a trade, how does that sound?
The Brembos will bolt straight on but I think you need to use R33 GTR brake lines and front caliper bolts if I remember correctly.
Hi Andrew,
hey mate where abouts r u located?
Hey man , you still have r33 brembo black series with rotors for sale ( condition/ thickness of rotors and measurements )
trade u my stock r32 gtr calipers for your set $850 if ur calipers and rotors are in decent condition
Hi,
I'm keen for fronts if anyone wants just the rears?
Otherwise, I've got a set of R32GTR calipers (non-brembo) to trade if you are still keen on that option?
They've just been painted brembo gold, so look pretty nice (with shaved nissan logo's).
Unfortunately I have lost the details to my old account, so this is my working one, and I dont have 10 posts so cant pm anyone :D
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
