  • Replies 205
Yeah, cause the AI player only bets a certain amount, even if you raid it 5k.. Do you do the 7, 9 & 10 trick?
.........7,9 & 10 trick?
I just make it however i can lol usually a 10, 8 and then king the 8
basically if you get 26 first on 2 out of 3 of them.. then you win.. done.. if the AI is going for it on one of them.. play the other 2..
Fair enough.
So ive just gotten to the brotherhood of steel, and ive already decided that as soon as i get power armour training, im shooting every one of them in the head! :blink:
lol i wont say why because i dont want to spoil it for anyone, but you will see when you get there :)
Yeah there are 5 add-on packs.. at least for Xbox & PC..
Point Lookout - A whole new island you get on a boat and takes you there
Mothership Zeta - Invesigate aliens
Operation Anchorage - Takes you back in a Virtual Machine to a war, also end rebroad minded person of that opens a door with awesome armour and a sword
Into The Pitt - Travel to Pittsburgh
Broken Steel - Extends the game after you die, you wake up instead and join the brotherhood of steel to finish of the enclave
Bonus with Broken steel is that it raises max level to 30.. Even if you start the game again
I traded my FO3 in for the Game of the Year edition.. Which includes all 5 add-ons..
Son of a bitch! I never knew this :P
I just did some Googling and yeah originally they were not available on PS3 but came out afterwards.
Hmmm maybe I will sell my version and get the game of the year version, or maybe just get New Vegas.
Descisions, descisions!
Son of a bitch! I never knew this :D
Get a 360 :P
LOL.. just get the Game Of The Year editio... Game had it for $32.00.. and then also go get New Vegas.. Win Win..
:huh: when was that? Wanna pick it up after I finish my exams this semester and the cheapest I've seen it for at the moment is around $60.
:P when was that? Wanna pick it up after I finish my exams this semester and the cheapest I've seen it for at the moment is around $60.
I'm talking about Fallout 3 GOTY Edition.. New Vegas doesnt have a GOTY Edition yet.. I saw it in Game around 2 weeks ago.. I traded mine in when EB had their sale on.. Picked it up for $37..
Xbox have rights to first release i beleive.. So will be released on other platforms just not out first..
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
