  • Replies 205
Yeah, cause the AI player only bets a certain amount, even if you raid it 5k.. Do you do the 7, 9 & 10 trick?
.........7,9 & 10 trick?
I just make it however i can lol usually a 10, 8 and then king the 8
basically if you get 26 first on 2 out of 3 of them.. then you win.. done.. if the AI is going for it on one of them.. play the other 2..
Fair enough.
So ive just gotten to the brotherhood of steel, and ive already decided that as soon as i get power armour training, im shooting every one of them in the head! :blink:
lol i wont say why because i dont want to spoil it for anyone, but you will see when you get there :)
Yeah there are 5 add-on packs.. at least for Xbox & PC..
Point Lookout - A whole new island you get on a boat and takes you there
Mothership Zeta - Invesigate aliens
Operation Anchorage - Takes you back in a Virtual Machine to a war, also end rebroad minded person of that opens a door with awesome armour and a sword
Into The Pitt - Travel to Pittsburgh
Broken Steel - Extends the game after you die, you wake up instead and join the brotherhood of steel to finish of the enclave
Bonus with Broken steel is that it raises max level to 30.. Even if you start the game again
I traded my FO3 in for the Game of the Year edition.. Which includes all 5 add-ons..
Son of a bitch! I never knew this :P
I just did some Googling and yeah originally they were not available on PS3 but came out afterwards.
Hmmm maybe I will sell my version and get the game of the year version, or maybe just get New Vegas.
Descisions, descisions!
Son of a bitch! I never knew this :D
Get a 360 :P
LOL.. just get the Game Of The Year editio... Game had it for $32.00.. and then also go get New Vegas.. Win Win..
:huh: when was that? Wanna pick it up after I finish my exams this semester and the cheapest I've seen it for at the moment is around $60.
:P when was that? Wanna pick it up after I finish my exams this semester and the cheapest I've seen it for at the moment is around $60.
I'm talking about Fallout 3 GOTY Edition.. New Vegas doesnt have a GOTY Edition yet.. I saw it in Game around 2 weeks ago.. I traded mine in when EB had their sale on.. Picked it up for $37..
Xbox have rights to first release i beleive.. So will be released on other platforms just not out first..
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
