Hey guys,
Time for me to get something a little more subtle/and maybe pay a chunk off my home loan if i can get a cash sale - I am very negotiable for cash :laugh:
Details on Build are as follows:
Engine/Driveline:
RB26/30DET 40 over thou
Ross forged flat top pistons
Ross forged H beam rods
ACL race series bearings
ACL race series rings
cryo'd and blueprinted crank
Custom high volume gated sump
Blueprinted and decked block
oil galleys, water galleys all bored and cleaned
new plugs throughout block
cometic 3mm metal head gasket
head acid bathed and decked
relinished cams
tomei stoppers
titanium springs
tomei valves and honed larger seats
Adjustable cam gears
ventilated lightweight flywheel
carbon ceramic clutch
rebuilt rb25 5 speed
custom tailshaft
KAZZ 2 way diff
KAZZ axles
FUEL SYSTEM
GTR in tank feeder pump
Custom 2l swirl pot
Bosch 044 main pump
Sard fuel regulator
HPI billet fuel rail
Cusco 700cc injectors
all barided lines and speedflow fittings used
Engine management
Autronic SM4 - top of the line controls everything
All hidden wiring to keep it tidy
Turbo/exhaust
Garrett GT35/40R with a 1.06 rear housing
stainless manifold all ceramic coated and heat treated
Full custom 4" stainless exhaust from the turbo
Intake/keeping cool
K&N filter
full stainless intake into turbo
Full stainless intercooler piping
PWR 100mm intercooler
Custom stainless extra large instake plenum with trumpets inside
100mm alloy Throttle body
PWR 40mm Radiator with custom shrouding - never gets hot
Suspension
Tein racing coilovers
Cusco strut braces front and rear
Cusco Sway bars
Drift pineapples
Adjustable arms - castor, camber, toe - fully adjustable
Body/Interior
Full rotisserie respray in solid Skyline blue
GTR interior, front and rear
nardi racing wheel
Full genuine GTR Front end
full stereo including sub (can be easily removed)
Rare rear window roof lip/wing
There are alot of little things that i have forgotten, guages, all of the custom things like catch cans, resivoirs etc all done in stainless...
Anyway this car is an animal to drive, and is equally at home on the track as it is prowling the streets.
Asking $18,000 or make a reasonable offer, will look at r34/GOOD r33's for swap or maybe a dual cab ute??
PM me on here with your number and i will MMS you pics, i dont have any on my work computer :)
Cheers for looking guys
https://www.sau.com.au/forums/topic/324187-r32-sedan-crazy-setup/
hey guys, like i said i cant get pics up from here until i get the digital cam, i can MMS you pics if you PM me your number, Wilba now has pics :)
Got it tuned yesterday again, we ran 700HP, then tuned it back to 500hp and 1770nm of tourqe...it was wheelspinning on the dyno and we had 3 big guys sitting in the back, this is no car for the faint hearted if you are throttle happy!!!
Also purchased RWC yesterday so it is ready to go, and all legal!!!
hey guys, like i said i cant get pics up from here until i get the digital cam, i can MMS you pics if you PM me your number, Wilba now has pics :banana:
hey mate very keen on a swaps, i have a 2000 wrx with some work done, it also has custom green respray, wheels bodykit etc. ring for more details and to send through some pics 0400773612
selling up already timmy MY OLD SKYLINE you have only had this for just 2 weeks
this is a 25/30 set up with 26 cam covers
they are not cusco injectors Try rockchester 680cc's
all piping is alloy
exhaust is not stainless its steel
the pistons are CP
are not titanium springs
does not have tomei stoppers
are not tomei valves
gear box has not been rebuilt
has not had a rotissery respray
strut braces are KTS brand
has GTR Front bar and bonnet only HAND Flared front GTST Guards
it is NOT a PWR Radiator it is a chinese alloy rad with standard fan and shroud
manifold is not stainless it is steel
intake manifold is alloy
the paint is not solid skyline blue it is ford focus blue
it is not a sard fuel reg it is a magnafuel reg
are not KAZZ Axles but standard skyline axles
  • 3 weeks later...
WHOA Sorry my bad I was sure I had seen that screen name trying to sell another rb26/30 for 10k with barely any information
This guy is okay someone please buy this
Good luck with the sale and sorry again
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
