Hi all,
I would like to cover my door trims with some Carbon Fibre flat panels but have no idea where I can get them from? Im aware that you can get after market 'molded' ones (but they cost heaps) so I literally just need two flat pieces big enough to cover my doors and then i'll cut to size. Should be a lot cheaper! Any ideas on where I can get that sort of Carbon Fibre?
Cheers,
Glen
I honestly don't know how you could cover your door panels with flat unless you are just doing some of the inserts that are totally flat.
Seriously have a look around a doing some covering, but you are going to be surprised how expensive just the raw carbon material is. It is about $70-100 per square meter in oz and about $30+ in the US.
Oh sorry man I made a mistake, I ment to say that I have taken the original door trims off my car (i've pretty much taken everything out of my car...) and now want to cover it up with Carbon fibre flat panel.
Link: http://www.skylinesaustralia.com/forums/in...t&p=5128026
Cheers,
Hi,
We have two flat panels available in Carbon Fibre. 80 x 80cm and 50 x 50cm. Both are 1mm thick sheets.
Please let me know if your interested.
Cheers,
Shane
Oh bummer they fall just short (well kinda) because I will need them more around the measurements of 110 x 50cm. :P
Oh bummer they fall just short (well kinda) because I will need them more around the measurements of 110 x 50cm. :)
Rob from www.hybridcustoms.com.au here in WA makes a true Carbon Fibre universal door skin with the dimensions being up to 1200mm wide by 1000mm deep with 40mm lip, images below are the finished product made for an R35 and some photos of them being infused.
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
