a mate of mine has just returned from a holiday in japan (the carnt) and put together this lovely compilation of stageas drifting at an RB meeting at Nikko :laugh:
enjoy
this has me even more pumped to get the manual conversion underway!
Edited by M I K E
https://www.sau.com.au/forums/topic/324208-stageas-drifting-at-nikko/
