Not really, but i have friends that have mechanical shops, panel beaters... im going to advertise mmyself do good rates etc. This one is non turbo though, its a 5 speed manual deisal, and do they really have problems? if soo then i might have another think about it! thanks Wopred3d, hmmm do u thnk these are unreiliable?>
the only problem ours had was the snapping of studs but that could have been turbo heat related, as yours is not a turbo it may be fine, also this is only one, isuzu are known to make a reliable truck, any jap trucks are usually ok as long as they are maintained properly, how many k's has it done?
400,000 on it .
Oh realy thats a good sign then. thanks man.
Thats pretty low for something that age, ours hasnt been driven for a few years and has around 800,000 on it, we also have an old international that is about to clock over a million and in the 7 yrs i've been there the only major works is a head gasket and gearbox.
  • 5 years later...
This is the first sau email i have had in a while, and its about a shit box tow truck, dam i posted a lot of shit on here.
Hey, it got you back on here! There is a positive out of the spam! :)
  • 4 years later...
Go for it mate, my dad started out unsure like you, now he always tells me 'if you don't take the dive, then you never start swimming.'
You'll start with one, you can work for yourself as a sub to get cash flow and it's like anything, you keep putting energy into something and it keeps growing.
______________________________________
https://www.geelongtowtruck.com.au/
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
