Just wanting to know wat kinda response we can get for a cruise on valentines day.
This is not an SAU cruise only as there will be other car clubs involved
Not going for a huge turnout
even something small will be good
might go for a nice cruise down the coast line catch a ferry across the bay etc
Once again we will be filming for some more footage for the Wateva. TV show.
more ideas welcome...
Bring your partners along..
Depending on numbers that we get showing interest will organise the event based around that..also would u prefer a day or night cruise?...
ill put up a few ideas in a poll and see wat you guys and girls think..
You can choose multiple times so make sure u indicate if you would like either a day or a night cruise.
Ta
A.
https://www.sau.com.au/forums/topic/32447-feb-14-valentines-day-cruise/
What about a option of BUSY?
OR maybe not a good idea ??? :)
NAh.. i'll be doing something with a lady no doubt, if i mention car's i'll probably get whipped
Just an FYI though, we got an SAU-GOR cruise a week (or) 2 after that ;)
and not everyone seems to like the idea of valentines day
lol
It's not so much the buys (most sky drivers are)
It's the females behind them :inlove:
:) like i said... im 99% certain that most females, if the phrase 'Let go on a Car Cruise' was mentioned on Valentines Day, the better halves would crack out the whip BIG TIME :whip:
but if your into whips, then it aint so bad :aroused:
lol ya i hear ya
if you got a mrs careful when u mention "cars" on velentines day
valentines day is great for some
personally im over it
if ur partner needs a day to prove to u he she loves u then somethings wrong
you should show it no matter wat day of the year it is
i guess u could always use the line..."but honey how can u make me chose between the two loves of my life"?
but somehow i dont think its gonna get u very far
and most likely end with a slap in the face
lol
well how about for valentines day that you organise to do something down'that way' and cause you have to drive there, you just happen to bump into a heap of other skylines driving as well..just stop for a driving break where the bbq happens to be hehe
thats what i have planned anyways hehe
Hope you feel better ambz :D any chance your keen on helping out with the autosalon this year?? just wondering :)
lols ta
would love to help out again
but unfortunately me is flat out with other stuff this year :)
but no doubt will come down and cheer u guys on! :headspin:
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
