  • Replies 311
Posted Images
When u mean other cars...can u bring any? or is it only skylines....? i have a skyline engine:)
This Event is SAUer-friendly; meaning that YOU ARE THE IMPORTANT ONE!
This means that you can ride your scooter up the Bells Line Of Road if you wish hehe...
Seriously, your VL is most welcome; and it can take part in Group 4 of the convoy.
Group 1 = R32s
Group 2 = R33s
Group 3 = Other Skylines
Group 4 = Other Cars 'n scooters
Enjoy the Cinema as well as the cruise too Nick! :D
How's the weather forecast for the 10th Oct atm guys?
Food can be obtained across the Hwy/Railway in Katoomba shops if required. It'll be lunchtime!
FYI...
Updated Info:- Payments have been received from the following Postcodes for Cinema Tickets in reverse order (ie from most recent to first)...
2020, 2173, 2221, 2641, 2132, 2761, 2128, 2747, 2774, 2541, 2609, 2289, 2067, 2747, 2148, 2747, 2481, 2617, 2162, 2146, 2077, 2250, 3132, 2128, 2173, 2615, 2755, 2747, 2750, 2755, 2166, 2163, 2750, 2044, 2567, 2560, 2227, 2541, 2615, 2557, 2527, 2777, 2206, 2127, 2914, 2795, 2785, 2113, 4210, 2615, 2203, 2795, 2166, 2095, 5013, 2138, 2232, 2148 :(
Ask our Organisers for anything you need on the day - they'll have Name Tags!
The Organisers will be doing a Recon (on Sunday week) to check one final time, where we'll pause on the cruise. BP Ultimate can be procured on the day on Bells Line Of Road.
But near Penrith you have a choice of all fuel types along Mulgoa Rd. near the Start.
hey terry, i am not sure if my car will be out of the mechanics by then or not, is it possible if so to just come along for the cruise? dont want to stuff you around with holding tickets or anything?
cheers
yt
cheers
yt
Certainly OK!
I hope your car has a fine bill of health by then too :D
Hi All!
I'm happy to announce the prize for the Best R32 GTR on the day!
John (aka kuma_j) has kindly offered his services to create us an exact replica of a Winfield R32 GT-R. This will include wheels, chassis and engine.
Here are some piccies of the awesome mini beast:
This is going to be an awesome day peoples, make sure you get your tickets!!! :D
Even the "BOOBY Prize" is worth over 100!!!
Best to mention your location aswel as the people reading this thread come from all corners of Sydney
Buzz Lightgear voice: AND BEYOND! :D
Anyone willing to give me a lift? In return Ill take photos of your car. Ill go halves of petrol. Being on L-plates has its disadvantages....
if you happen to be close by to me and the ms's is ok with it ill be happy to give you a lift
Hopefully I'll make it for the cruise, have to get to the airport later that afternoon so the movie might be pushing it! Will gladly make a donation though :)
Will hopefully have a 'photographer' tagging along in the form of a friend or possibly my sister!
You guys above...
The more R32s the merrier, even if you can only make the start! There'll be cameras all over the place!
And the more Nissan-nuts inside the Cinema, the more hootin' and a hollerin' there'll be! :banana:
FYI...
2148, 2285, 2289, 2906, 2020, 2173, 2221, 2641, 2132, 2761, 2128, 2747, 2774, 2541, 2609, 2289, 2067, 2747, 2148, 2747, 2481, 2617, 2162, 2146, 2077, 2250, 3132, 2128, 2173, 2615, 2755, 2747, 2750, 2755, 2166, 2163, 2750, 2044, 2567, 2560, 2227, 2541, 2615, 2557, 2527, 2777, 2206, 2127, 2914, 2795, 2785, 2113, 4210, 2615, 2203, 2795, 2166, 2095, 5013, 2138, 2232, 2148 :)
There'll be some more surprises popping up on this thread real soon!
Hi Terry
Regarding this separate groups 1, 2, 3, .. when it comes to the cruise, some of the guys I intended to have come with us are not too happy about this arrangement because not all are in skylines nevermind R32s so their argument is " why should we come out with you when we are not going to cruise or see you all day long" and I see their point, most are coming just to see my car and be able to cruise with me for part of the day at least if not more.
So if things remain as they are we might not see all the cars come out due to the fact of friends being separated on a same cruise. What are your thoughts on the matter?
Regards
star32
