normasta me and my mate were talking to the president of ssa? lol and the guy with the r33 gtr with the number plate jmw sorry which one are you haha
I was the one who rugged up like he was in the alps, not in Kadina :(
https://www.sau.com.au/forums/topic/324712-new-to-sau/#findComment-5291279
welcome to sau mate...i think i remember talking to you at some stage....i think when we were about to leave the premises :(
https://www.sau.com.au/forums/topic/324712-new-to-sau/#findComment-5291571
Hmm, was it you who turned up in a silver 32 or maroon 33? I spotted these cars pulling into the off-grounds car park after lunchtime.
I only noticed, because with all the Fords and Holdens (and bogans), it was a freshing sight to see :P
Welcome to SAU. Please be encouraged to join up with SAU-SA ... south australia's only CAMS affiliated Skyline Car Club. :(
https://www.sau.com.au/forums/topic/324712-new-to-sau/#findComment-5291613
