oh no there is a way....get everything out of the way heater hoses, coil pack loom, vacuum hoses i mean everything. then you can get a hand in there and a screw driver and you can fiddle around with it....
also you can loosen the engine mounts loosen not take off. then jack the engine on a tilt to give you more room.
it is very fiddly and complicated and so frustrating but it can be done...
its basically a real prick of a position to get to, in between the firewall and the rear of the motor. persistence is your friend. i ended up taking my bonnet off to get over the area more ergonomically if i remember right, i did it ages ago...
but why would those lines "keep cracking". I've never broken one in the race car (broken lots of other stuff!).
do you have the turbo/sump pipe brackets on? Are the manifolds OK (not cracked)?
some other problem here
Not sure which Turbo/sump bracket you mean but as far as i can tell everything else is fine..just pulled it all off to replace cracked manifold studs thought id replace the whole line while it was apart
The original line has been cut with the flame proof rubber hose put in place, the hose but gets dry and hot and eventually cracks the outer tubing near the turbo ex housing
Was just wondering how hard it was to change, appears its very hard..Maybe i should try run the hose away from the turbo more so it doesnt get so hot..If you guys arent having problems it must be my setup, I'll drop by pirtek maybe see what hose they have
Cheap way is just to cut off the metal line and replace the mid section with abit of good rubber hose and clamps.
will heater hose do or is there a particular hose better suited to something so close to the turbo and manifold?
the on mine that has split (im assuming its the same one) comes from the manifold to the turbo, when i changed my turbo i dont remember there being a sump bracket there, mine has split the rubber hose, its only about 3 or 4" long and goes around the rear drivers side corner of the block.
Helped a mate replace this hose on his car after it burst one night on the dyno, it connects to the head flange water return under the plenum. With the plenum off its a pretty straight forward job. Getting the plenum off is the bit that tests the patience. There is a barbed fitting under there that a -6 hose fits, run this to the metal block that has the vacuum line attached also. Cut the pipe off and drill and tap the rear of it to accept a barbed fitting and attach the -6 hose.
good luck
EDIT: this was on a GTR...for GTS-t just plug the line and run it to the radiator outlet neck on the engine. That way can show off your bit of bling braided hose!
Edited by Supa Steve
Ok found it..didnt have to take the bonnet of or anything, did have cam covers and aac out which helped...helped cut my hands on the sharp edges of the head that is :D , but with some perseverance got that prick of a bolt out, have just run gates flame proof hose all the way .
Have run hose down and back up to turbo to keep it away from the ex housing a bit,,it now connects vertically not horizontal if that makes any sense..
Pretty sure water can pump up hill cant it?
It doesnt go any higher than original, goes from rail under plenum straight around back of head under heater hoses,but instead of going straight to turbo goes down and then back up again ..
By bleed bolt is that the bolt right up the top at front of the plenum?
I was wondering what that was for
Edited by Arthur T3
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
