Hey everyone
I have got a 2way Cusco diff and would like to buy some oil. On their website they say use an oil with a viscosity of 80w-140.
I rung up the local workshops(Xspeed, Intune, cypher industries, Nissan).
Xspeed said they will ring me back, cypher industries said they have redline oil however they recommend to use a 75w-90 because 80w-140 is to thick.
Intune and Nissan both just dont stock any of those oils, Nissan dosnt stock Nismo oil either.
So i just wanted to know what viscosity should i stick to? 80w-140 or as recommended by the workshops 75w-90? The car is going to be used on the track and also as a daily.
Finally does anyone know who in Perth holds redline, motul or nismo oil to buy?
Cheers guys, ni
https://www.sau.com.au/forums/topic/324793-where-to-get-oil-for-diff/
Hey everyone
Cheers guys, ni
Either 75/90 or 85/140 will be OK. Make sure it is a LSD oil. I believe most aftermarket diffs require a mineral oil, I know Kazz recomend mineral and say to avoid synthetics.
What does the Cusco instructions say?
Hey guys
I think ive found the oil i am after which is the Motul 90PA Differential Oil..
Was reading a few threads on forums that had people talking about the Cusco 2ways and they found the Motul 90PA Differential Oil to be the best solution. It's a mineral based oil also..
Has any one else used this on there diff, if so how would you rate it?
thanks for all the help :D
Ni
No problem if you don't mind the extra wear and noise
I use Castrol saf xa 75w90 in my cusco 2 way.
Drives mint.
Can get it from most auto shops
Hey guys
Hmm i have no idea now which oil to choose. i say this because im getting a 50/50 opinion where some people state that the75w-90 is the best option, then other people say use a thicker oil such as a 80w-140.
cypher industries said that the 80w-140 will be to thick for a car that is also used on the road and that when i come into tight turns it may be to tight, hence why Zac said to go a thinner oil such as the 75w-90..
But then in the cusco website they state a 80w-140, so all in all im more confused about what oil to get then i was before.
I looked at the Motul range (as ive heard they work great with the 2ways) however the Motul 90PA is the only one which is mineral based. the 75-140 oils are all fully synthetic.
Hey Steve
I am leaning towards the 80-140, 85-140 viscosity
Using an oil with such an viscosity in your diff have you found any problems when coming into tight corners or round about?
Cheers, ni
Hi Ni,
Now you are coming to what can be a frustrating but also rewarding part if owning a performance car
i.e. Knowing what suits your purpose best.
Best option IMO is do some r&d yourself - diff oil isn't too expensive, so try the 90 weight Motul, see what
you think, then try the 140 weight and do the same - that way you will know what is best for YOU
and don't be scared of synthetic oils, synthetics count amongst some of the best in the world, also, not all oils are created equal, some 140 weight oils will give alot better results than others (I have used both valvoline and a
couple of different castrols) I have also used 90 weight, but changed it
out about 2 days later cos I didn't like it
as for roundabouts/tight corners, you will most likely find the diff will lock and the tyrese chirp, or if you are just rolling around, the diff may clunk a little (I have found this is worse with lighter oil than heavier, the heavier oil quirtens down the diff - on the ones I have used anyway)
FFS its all the same! dosen't matter what brand, make sure its mineral and is suitable for LSD. Then chose your viscosity! All the viscosites mentioned in the above posts will be OK.
For gear oils most oil companys use the similar additive packs and the base oils usually come from the majors ie Mobil, Shell, BP. So any reputable brand will be fine. Dont get carried away with brand names, do you really think so called specialists like Motul, Redline, Royal Purple invest more money into research than regulars Mobil, Shell, Castrol and so on? I dont think so!
Ash
Hi Ni,
Hey dude
Thanks for all the information man, will try out a few oils and see how it goes from there.
Ni
Ash
no. i never said anything about a brand name however i read reviews and most guys on forums such as Skyaus, Hardtuned post good reviews
on the motul range, HENCE why i asked about it! not because i like the name nor care. i will go for a Mineral based oil as stated.
thanks, ni
Hey everyone
Alright guys I’m going to try two oils out.. Firstly i went for the Motul P90A because 1) there’s been positive feedback saying they are great in the Cusco 2ways and quieten them down without it slipping. 2) The original owner of the diff said he used the Kaaz 2way oil which is a 80w-90.
i will run the motul oil first, if it seems to be an issue i will change over to the higher viscosity Castrol LSX 85W 140 and try that as Steve stated.
Thanks for all your input guys
Ni
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
