Hi Fellas,
I've decided to part with my car. I've spent over $40,000 on this car and have receipts to show.
Details are below:
Engine - Built by Pro Engines June 2009 and still under warranty:
* RB30 Bottom End
* ACL Forged Pistons, Rings and H-Beam Rods
* Nissan N1 Oil Pump
* Head Porting
* HKS 256 Inlet 264 Exhaust Cams
* Adjustable Cam gears
* GT35R (GT3582) Turbo 0.82 A/R housing
* XTR Highmount Exhaust Manifold
* Tial 38mm External Wastegate
* Plazmaman Plennum
* Splitfire Coil Packs
* Nismo 740cc Injectors
* Bosch 044 Fuel Pump
* 3.5 Inch Straight through exhaust (with custom piping - optional screamer pipe or plumb back)
* GReddy Front Mount Intercooler
* Turbo Heat Bag
* Jim Berry - Fully Monty 3800lbs 900HP race clutch
* Bosch Alternator
* Custom Fibre Glassed Cold Air Intake
ECU - Tuned by Autotech in Canberra
* Autronic SM4
Suspension
* Bilstien shocks
* K-Mac lowered Springs
Exterior
* DR-1 Wheels -9.5 inch on the back and 8.5 inch on the front- very light racing wheels, only weigh 10kg each
* Khumo tyres - 265 on the rear and 235 on the front
* 400R Side Skirts
*Tinted Windows
* Xenon HID Conversion Kit
Interior
* Autometer boost Gauge with Chrome Cup
* Jensen VM9512 7 Inch Touch Screen DVD player with Bluetooth and iPod/iPhone connectivity
* Original Skyline Floor Mats
The engine is still under warranty. This car has not failed me in the slightest way since day 1 of the build. Only 7,000km have been driven in this car since the engine build.
Registration on the vehicle expires April 2011.
Standard parts (ECU, Wheels, camshafts, springs intercooler etc etc) will come with the car.
Price $24,900 ONO.
Thanks.
https://www.sau.com.au/forums/topic/324799-fs-r33-gts-t-rb2530-363rwkw/
  • 3 weeks later...
  • 2 months later...
Seeing as I took the time to go out of my way and help you out to sell your exhaust manifold, I'd appreciate it if you did the right thing and got back to me about sending the other one back, I won't be supplying one to him until you do.
Kyle
  • 3 weeks later...
  • 5 weeks later...
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
