hi all
Can any s2 stagea onwers that have standard suspension tell me what their suspension is like?
well mine is pretty crap i dont know if they are gone or thats the way the standard suspension is!
i can feel all the bumps, the ride is a bit rough and it the suspension feels hard to me
well this car is for my wife to drive and we are having a baby soon so i wanted the suspension to be smooth and absorb the bumps
what should i getting?, i have a new rear sway bar coming and i'm thinking of taking the car to Trutrack.
i like the standard height cause the front dayz bar fits over the curb when parking
any thoughts would be so greatful
thanx guys
https://www.sau.com.au/forums/topic/325046-is-my-suspension-stuffed/
check out the shocks - most likely lost pressure and weeping heaps. ie gone, shot.
use stock springs, order Bilstein shocks to suit with some circlips and grooves slotted into the shock body (to adjust height).
best bang for buck. my stock S1 shocks were gone at 80,000kms. weeping, too easy to compress by hand.
for the past 20tho kms Ive had Bisltein shocks, stock springs, lowered 350mm ride height, Whiteline swaybars and bushes
awesome. a little hard under 80kms on bumpy roads, but above 80km in the Hills its awesome. been to the racetrack a few times too, handles fantastic.
Just get the suspension place to have a look.
You might have aftermarket Jap suspension which historically had been a little on the firm side.
Some of the newer Jap stuff is pretty good but like Tangles said there are plenty of good options out there with Bilsteins.
First see what you have then come back and work out the best way to proceed before spending money.
A good suspension shop should have a look at your car and give you a free assessment. Check for aftermarket suspension.
The traditional check for shocks is to push each corner of the car down hard and let go. It should spring up and stop dead. If it goes up and down once or more the shocks are shot. A proper suspension shop will have a machine that can measure the rebound and show it on a graph.
If you have aftermarket shocks they may be adjustable. If not or if your standard shocks are shot a set of Bilsteins would be the answer valved to your requirements (i.e. not too stiff) and retaining the stock springs. A stiffer rear anti roll bar will improve cornering without affecting your ride quality.
Rear strut brace is the most dramatic handling improvement you will make, if you can afford the loss of practicality. After that, shocks and springs like the rest say, and don't skimp on decent bushes...
Should the measurements from centre of wheel to arch be the same for all four corners?
mine is out by 5 cm front to back
yeah thats about right, from memory mine were higher at the front, something like 390 front, 380 rear. when my rear shocks let go the car got really "wobbly", if you stick your head under the back of the car you'll be able to see if they have blown out, they will be covered in oil.
we had the standard suspension in ours up until a couple of weeks ago. we'd done just over 100,000km and ours were proper screwed.
when i took the suspension out, i pulled the dust boots back to have a look and in three of them the bump stops fell out in tiny pieces, in the fourth one, the bump stop had already fallen out in pieces and parts of it stuck in the spring :S
put the new coilovers in and the ride is 10000000% better. no wobbling any more. only bitch is that now the rear rim is scrubbing on the suspension on occasion. we've got aftermarket rims though, so don't fret if you've got stockies :)
Just got mine back from a diagnostic session to identify a slight shudder I have had for a few months: it would appear my 40,000km-old front left Bilstein shock is on the way out: bit disappointing, but I guess that's all part of the modding game....
In hindsight, I suspect it may have been faulty since new, as I have been trying for ages to identify a strange intermittent thump from the front left corner around right hand turns...
just got back from a pedders saftey check
problems found were
- worn link rods $195 fitted
- sum play in the steering rack POA
- front bump stops $192 fitted
- rear bump stops $192 fitted
- rear shocks fail $992 koni fitted
and to get rear sway bar fitted 95$
am i better getting a BC coilovers? are they easy to fit yourself?
any thoughts
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
