hi i have tryed to do a search but can only find info in the r33 models ,
so if you want to post and say do a search maybe back that up by directing me to the page that comes up in the search as i cant find it !!!.
no i have an r34 gtt series 2 and i dont like the front bar as its restrictive for the radiator and inter cooler and when i put a front mount on i wont get the full benifit . so i want to fit an r34 series 1 front bumper bar , iv read on another post (i searched for ) that on the r33 to do this you have to change the bonnet , headlights, front reo and front quarters , is this the same for the r34 ???
i do know ill have to change the indecaters but thats a given as there in diferent places and are totaly different lights,
if some one has already done this i would love to know how you went about it
thanks for your help
  • 3 months later...
hey i know this really isnt the place to post this but i cant get a straight answer of where i can find stock photos for a s1 and s2 gtt r34 2 door manual.
can anyone help me out?
hey mate my car is a 4 door so that wont help but im sure if you have a look through the garage section you will find some , ill have a look on google and see what i can find !! and post the link or photo for ya
only difference thats a put off on the series 2 is the bumper but after a bit off stuffing arround i managed to fit a blitz intercooler in and it hides rather well .
series 2 the interior plastics dont scrach as easy and seats steering wheel are two tone in colour .
i love my car and iv come to like the look with the s2 bumper as the police leave me alone
also swapping bumpers can be done but it involves removing or replacing front reo and the brackets under the head light (all costs alot )
so if you go series 2 keep in mind if you want to put a kit on it with new bumper your looking at $300 on top to get the series 1 reo and brackets to get it to all fit .
ah i see. hmm yeah i think i would prefer a s2, just because there newer and scratch proof and what not you know? hah
although i dont like the front bumper :D how much would it be for a different bumper similar or same to a 98?
isnt the spoiler different too?
im not sure about the rear as my 4 door only has a boot lip but you can pic up a series 1 bumper for anthing around $150 to $200 2nd hand
then you will need the front reo and headlight brackets ,
just make shure you get the car you choose checked by someone that knows skylines !!,
then enjoy it lol
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
