FJ20DR30 Posted June 18, 2010 Share Posted June 18, 2010 Hi anyone here using a vg30 turbo? if so does anyone have an aftermarket down pipe ? and or does anyone know where to get them? im hoping to get one with a screamer pipe? iv got a guy that can make one but the issue is that he is not sure how to seal the air between the wastegate and exhaust. any help? im aware of the of the legalitys so please dont post on here about it! Link to comment https://www.sau.com.au/forums/topic/325382-vg-30-downpipe/ Share on other sites More sharing options...
FJ20DR30 Posted June 18, 2010 Author Share Posted June 18, 2010 also if someone knows the max boost of a vg30 it would be great to know Link to comment https://www.sau.com.au/forums/topic/325382-vg-30-downpipe/#findComment-5299957 Share on other sites More sharing options...
Ghostrider Posted June 18, 2010 Share Posted June 18, 2010 Rear housing flange is same as RB25 Link to comment https://www.sau.com.au/forums/topic/325382-vg-30-downpipe/#findComment-5300722 Share on other sites More sharing options...
Factory 5 Posted June 19, 2010 Share Posted June 19, 2010 there are 5 different VG turbos, post up some pics and that will help a hell of alot more. Link to comment https://www.sau.com.au/forums/topic/325382-vg-30-downpipe/#findComment-5301354 Share on other sites More sharing options...
Ghostrider Posted June 27, 2010 Share Posted June 27, 2010 there are 5 different VG turbos, post up some pics and that will help a hell of alot more. How so this make any diference to the exhaust rear housing that concerns the dump or downpipe??? It would be a real shame if we stuck to subject huh! Link to comment https://www.sau.com.au/forums/topic/325382-vg-30-downpipe/#findComment-5315425 Share on other sites More sharing options...
Boof Posted June 30, 2010 Share Posted June 30, 2010 Because there are probably 5 different exhuast housing designs Dennis!?!?!?!?!? You do realise there are a range of VG turbos out there ya know Link to comment https://www.sau.com.au/forums/topic/325382-vg-30-downpipe/#findComment-5321879 Share on other sites More sharing options...
Boof Posted June 30, 2010 Share Posted June 30, 2010 also if someone knows the max boost of a vg30 it would be great to know Mate was running a VG30 turbo on a FJ20 with full exhuast and FMIC and it was running 14psi Link to comment https://www.sau.com.au/forums/topic/325382-vg-30-downpipe/#findComment-5321887 Share on other sites More sharing options...
FJ20DR30 Posted June 30, 2010 Author Share Posted June 30, 2010 LOL ill take some pictures of it on the weekend its in the car so whats the best part of the turbo to try take a picture of to help identify it? has anyone heard of down pipes being made for these with screamers? Cheers Link to comment https://www.sau.com.au/forums/topic/325382-vg-30-downpipe/#findComment-5322337 Share on other sites More sharing options...
Ghostrider Posted June 30, 2010 Share Posted June 30, 2010 Funny thing is the importers say the rear flange is the same Link to comment https://www.sau.com.au/forums/topic/325382-vg-30-downpipe/#findComment-5322370 Share on other sites More sharing options...
Ghostrider Posted July 1, 2010 Share Posted July 1, 2010 And I have had 4 VG30 turbo's here, 3 with diferent casting numbers on the compressor housing, but all with identical exhaust outlet flange pattern. I had one Hi Flowed which I still have and never used and gave the others away or swapped them for bits I could use later on. I also have an R34 NEO turbo and that has the same flange pattern as the VG30. D Link to comment https://www.sau.com.au/forums/topic/325382-vg-30-downpipe/#findComment-5322614 Share on other sites More sharing options...
