The Police in Victoria, seem to 'randomly' pull people over. Now if you drive an import, especially a skyline you're more likely to be pulled over. Especially if when they check your number plate before pulling you over, you have an ethnic sounding name!
Now, whats more, is that once they do pull you over and you comply patiently with all their bullshit talking, they search, yes spend 20 minutes searching for something to do you for! How is this fair? Then you have to pay a fine or putting a whole in your own car! What the hell is this world coming to? Where the hell is the freedom?
Revenue raisers, they dick people for that, but you can be a serial killer and live in our prison system off our money!!!
https://www.sau.com.au/forums/topic/325403-cops-and-road-worthy-certs/
Sorry i don't know how to use this properly, but how is it your fault when it was approved by an engineer, and then gained a road worthy cert. THEN when pulled over again, it miraculously wasn't roadworthy any longer! And no new mods were made. And it WAS a legit cert to begin with, since VASS certs can only be given by properly accredited people, no?
Edited by SliikChik
What did they get you for?
Cops don't really care about certificates, especially if you've been a naughty driver or given them attitude. Their job sucks some days and they don't need some punk telling them that their drift was "accidental".
the girl has a valid point by saying skylines are NOT randomly pulled over, they are targeted, which isnt fair ofcourse.. but the rest of this post was rather useless and the original point is not even worth making a thread over lol......
too many of these threads!
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
