I'm bored today so I felt that I had to post something totally irrelvant to cars and the like.
How many Vic SAU goers visit Hard Kandy on a Friday night?
I'm a reasonably newbie at going but I have nothing to say about it besides I'm hooked!!! :rave:
The first time was just before Xmas and then I've been the last 2 weeks running and it has gone off in a big way everytime.
I was kindly introduced to HK by Wardest and I must say that it one of the best things I have ever experienced.
It gives me something to look forward to during the week, especially today as not only is "Hump Day" but it is only 2 sleeps until the next Kandy session!!
Unfortunately I won't be there this Friday due to other committments but I will definately be there next Friday and other Fridays to come.
https://www.sau.com.au/forums/topic/32563-hard-kandy/
  • Replies 65
booooo to u too!!
:D
i only went once when i was chilling down outside with my cousin at cage... went in for about 20mins and came str8 back out again... too many heros with their shirts off and dancing like gorillas.
https://www.sau.com.au/forums/topic/32563-hard-kandy/#findComment-652632
mmm, DJ_Lethal and i go to Billboard every Sat night (not the Hard Kandy night)
But out bartender (yes... we know him by name we are there so often) says that friday nights go off just as good.
In a hardcore way.
So i'm planning to go one night soon and check it out.
https://www.sau.com.au/forums/topic/32563-hard-kandy/#findComment-652664
Bugger Kandy and the Cage - go to the Mansion! (Now Im showing my age!)
Actually if you are getting into Kandy/Bubble etc try the Frantic events (held at rOOm680 every now and then on a Friday. Used to be held at different locations - Palace, Dome, Capsule) Best Hard House nights out in Melb by far (or used to be when I was clubbing) Free super-doopers rock.
http://www.frantic.com.au/fl_index.html
https://www.sau.com.au/forums/topic/32563-hard-kandy/#findComment-652667
Admittingly, I haven't been to Bubble or Bass Station yet but am intending on going in the very near future.
For the timebeing though, there is no alternative to the Kandy.
I have met some people who have been going for over 3 years and they reckon that it is simply getting better as time goes on.
Scott Alert is a dead set legend and one of the best DJs I have ever heard anywhere!!!!
I have found Nirvana and it's name is Hard Kandy!!!
Oh and BTW, Nark, for the fact that you are leaving the Skyline fraternity, noone is listening to you anymore :whip:
https://www.sau.com.au/forums/topic/32563-hard-kandy/#findComment-652751
Hey leewah this is from my gf :D
"hehe how old is leewah to only just now find out about kandy ? it was good when i went but hopefully he will move on lol to some hardcore stuff not that there is any good clubs like cage anymore.. some one should buy him a ticket to a rave and open his eyes up :P"
lmao u go girl
https://www.sau.com.au/forums/topic/32563-hard-kandy/#findComment-652829
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
